Question about Maytag Dryers
Maytag Dryer makes a horrible noise when drying clothes
It makes a loud noise when dryer clothes
MNTECH
  • 1543 Answers
SOURCE: Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Posted on Dec 06, 2008
SOURCE: dryer makes alot of noise when drying clothes.
First you will have to locate the two screws inside the dryer. Open the door and look up inside the trim around the opening of the dryer. Take them out then the top of the dryer will come right out. Look at the very from of the dryer. There should be 4 small "slides" attached to a trim piece. If there are any missing that is probably your problem. I just went through this problem. The pieces each are no longer than an 2" each but cost almost 8.00 a piece. They are easy to replace though. You might also have to replace the whole trim piece as I did because it was completely worn out. Very easy to replace.
Posted on Jan 13, 2009
  • 686 Answers
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Posted on Mar 04, 2009
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
Posted on May 26, 2009
pumpkinman
  • 1147 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 13, 2010 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Dec 06, 2008 | Dryers
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
