Question about NAD T751 Receiver
Right surround channel not working in some modes
I have had this receiver for years and had no issues, but it recently developed a strange problem. In test mode, the right surround channel produces no sound. Nor does it produce sound on inputs video 1, 2 and 3. However, when running on Ext 5.1 from a DVD player, all channels work perfectly. Since it works fine on Ext 5.1 the issue is not with the speaker cabling. And since it is broken in 'test' mode, it is not a problem with the source leads. Something must be going wrong within the receiver. Is there some way to reset the software or some other trick that might put it right?
  • Andrew Sellars Oct 31, 2007
    Yes - the problem was as you said. That grey harness had somehow got stuck up against the casing and a connection was lost - just moving it around to give it some space fixed the problem and all is fine now.  Many thanks!
I had the same problem with the right channel.    It turned out to be a broken wire inside the receiver; it can be found connecting from the main PCB to the card for the 5.1 board.    After repairing the broken wire, it has worked fine.
The harness connects the 5.1 low level signals to the board which are then redistributed to the amplifier section.     It is a bundle of wires in gray casing and with red, black and white wires (with shielding).
Find the offending wire, repair or replace and it should be fixed.
Hope this helps
Posted on Oct 27, 2007
SOURCE:
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
KENWOOD KR-V8030 SPECS
I have had this exact Receiver and this is taken right from the specs. in the manual, "120 watts per channel RMS" at 8 ohms - this is in Stereo mode (2 speakers) only". When surround sound is used, "75 watts RMS for Front and Center speakers and 15 watts RMS for rear (surround) speakers. From experience, the Stereo only mode is definitely stronger/louder than when switching to Surround. Most newer receivers are the same wattage regardless of mode.
Feb 19, 2012 | Audio Players & Recorders
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
Rear speakers do not work
Make sure of what audio mode you've set your receiver to, as well as what the source audio signal contains.
Some modes, such as Dolby Digital/Pro Logic will adopt the input format, and subsequently use only the front left and right speakers if there are no LFE/Center/Surround channels present. Setting the mode to Pro Logic II or IIx, on the other hand, will force a signal to be spread out to the various extra channels.
Using the Automatic Field Detect mode will usually provide the most appropriate solution for the input signal, otherwise.
Also note that if your audio source is from a PC and you are playing games, some games will, when you are using the digital output of many sound cards (most notably the Sound Blaster Live! and Audigy 1-2 and Audigy SE model cards) output only stereo as their signal, but still in a digital format. Your receiver will pick this up as a stereo specific signal and avoid using the subwoofer, center and surround channels.
Unfortunately, for those cards, there is no work-around beyond using analogue output or getting a more recent, better compatability sound card, as it is a limitation between the drivers, the card and the game in question, rather than your receiver that has the issue.
If the above doesn't help alleviate your issue and/or you could clarify on what your source audio is and whether you encounter this issue with all source-types or not, please post a follow up response.
Mar 20, 2010 | Sony STR-DE915
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
Open Questions:
NAD T751 Receiver Logo
389 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
