Question about Reddy Heater-30-55,000 BTU Variable
Heater will not stay lite
I have a 30,000 propane reddy heater and when I go to lite it it lites fine but when I take my finger off of the gas supply button it kills off the flame no matter how long I hold it in for even if its for thirty seconds like it says or three minutes what should I do ?
  • Anonymous Feb 04, 2009
    When I release the gas regulator button, the gas stops.
I have a All - Pro propane heater it too was doing the same thing hold the red gas button in it runs fine take finger off it shuts off the gas, I found it to be the thermocouple was bad.
hope that helps
Posted on Feb 05, 2009
Sounds as though your heater is a bit different than mune - I havwe no gas supply button, at least I don't think so. I just replaced my nozzle however at the recommedation of a recent contact to this site. It worked. The replacement packaging suggests annual replacement, so I think I was due - after ~12 years!
Posted on Feb 01, 2009
Model rlp50 50,000 propane heater fan will run, will light, but won't stay lite when you release button, fan still runs
i have the exact same heater with the exact same problem. tested the thermocouple seems to be fine, tested the relay, it seems to be fine, could it be the gas valve????
Jan 12, 2011 | Reddy Heater-30-55,000 BTU Variable
My 35000 btu will not stay lit. after i take my finger off the propane gas butten the flame goes off. what is wrong. this is a ready heater
I would venture to say that it is the thermocouple not picking up signal to keep the gas valve open. You can try cleaning the bulb end with steel wool and positioning it in the flame remember the hottest part of the flame is out on the end.
Dec 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
My heater wont stay lit
Chanches are the thermal couple a safty divice is gone bad. they don;t cost a big bunch and the parts store at a local propain dealer may show you how to install it. its no biggie. Good luck. DFD
Apr 12, 2009 | Reddy Portable Forced Air Propane Heater...
I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
Jan 16, 2009 | Heating & Cooling
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
146 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
