Question about Vacuums
Vacuum will not turn on
The vacuum cleaner was working fine one minute and then I shut it off. I could never get it to come on again. I can't see any reset button or fuse listed in the parts decription. The switch seems to be working fine (although it could have gone bad I guess) and the power cord seems fine also. Is there a fuse located on this machine (and where is it located) that may have blown?
  • 3 more comments
  • Mike Hayes Feb 14, 2009
    This is a Sears Kenmore Progressive Canister Vacuum (Model 116.21813)
  • Mike Hayes Mar 06, 2009
    Where is this Motor Reset button located exactly? Is it located on the inside of the machine somewhere. I thought I throughly checked inside and out of the vacuum for this already!! Please be specific. Thanks
  • royzee May 11, 2010
    Hi, what make and model is it please?
    Hi
    Waht model and make is it ?
  • Philip Gaut May 11, 2010
    What make and model of vac is this???
Kenmore Model #216.37000 does it have a reset button. I cleaned the filter and it still will not go on.
Posted on Mar 08, 2013
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Posted on Mar 02, 2009
Shark handheld vacuum shuts off after 10 to 20 minutes. What is the problem?
The motor probably has a heat sensor overload protector to protect the motor from burning out its motor windings. There is nothing wrong with the vacuum itself.
Apr 26, 2015 | Shark Handheld Vacuum Cleaner SV75SP
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
The vacuum cleaner works for a few minutes then shuts off.After a few minutes it will start again,but soon shuts off again.
There may be as many as three air filters in the vacuum. Remove and thoroughly clean all of them and try again.
Gary
Apr 18, 2011 | Hoover Vacuums
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
The unit works well for 3~4 minutes and then stops. Wait another 10 minutes to cool down and it works again but the same issue happens again and again. It is a brand new unit. I read the manual for the...
Hi, I have a Hoover Bagless myself. I also have worked professionally fixing Vacuum Cleaners. There may be some material caught between the roller end and the end bearing or the edge of the roller compartment. This could be causing excessive friction causing the motor to overheat. Like a piece of carpet fabric that wrapped around the end. However, that is not supposed to happen to a vacuum cleaner. If you turn the vacuum cleaner over, exposing the brush, you may find it. And be able to remove.
HOWEVER: This is supposed to be a premium Vacuum. It has a very high rating. It certainly is still covered under warranty. I would take my receipt, be safe, and exchange it.
I hope this helps,
Have a Happy New Year
Best, Mark
Jan 01, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
I changed the motor in my Dyson Animal hoover and works fine but after 15 minutes it stops as if it was turned off, if i leave it for a period (2 hrs)it will start up again and work for a further 15 mins...
Hi there
All Dyson vacuum cleaners are fitted with a thermal cutout, which will switch off the motor if it becomes too hot. This is normally caused by a lack of airflow to the motor, i.e caused by a blockage or a dirty filter.
I would make sure that you have completed the full blockage procedure and have thoroughly washed the filter and see if this helps.
Kind regards
Darran
Dyson Customer Service
Apr 19, 2010 | Dyson DC05 Cylinder Bagless Canister...
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 | Vacuums
After I run my vacuum for a couple of minutes it shuts off. If I unplug the vacuum and plug it into a different outlet most of the time it will start working again.
I would say check inside the plug and make sure the connections are tight. If the vacume runs fine on the other socket outlet then it will bw a faulty socket which cuts your hoover out. Can buy a new socket frount from diy stores for about 2-3 pounds. If the hoover also cuts out on the other sochet it will be a temperature cut out device on your hoover. If this is the case empty the bag and give it a good clean and get rid of any accumalation of dust/dirt
Jun 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My bissell deep clean carpet shampoo machine does not spray,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yfggf
Apr 18, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
HOOVER 6430-900
Hoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
(function(){ var e9 =new expo9_ad(); e9.size ="160x600,120x600"; e9.showAd(); })(); _qoptions = { tags:"ADSDAQ.LAWPOLITICS,501500," }; _qacct="p-01-0VIaSjnOLg";setTimeout("quantserve()",3000);
January 16, 2007
Hoover
hoover.jpgHoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
Whirlpool Spins Off Hoover
Hoover Recalls Self-Propelled Vacuum Cleaners
Consumer Complaints
Hoover Company Inc. has agreed to pay a $750,000 civil penalty to settle allegations that it failed to report to the U.S. Consumer Product Safety Commission (CPSC) the sale of vacuum cleaners with defective on-off switches that can overheat and cause the vacuum cleaner to catch fire.
In April 2005, Hoover conducted a recall of 636,000 Hoover Self-Propelled Upright Vacuum Cleaners because of defective on-off switches.
In June 2004, after CPSC received notice of several vacuum cleaner incidents, the Commission staff requested Hoover provide a full report of incident information. In July 2004, when Hoover submitted a full report, it had notice of 260 consumer incidents, of which 141 involved reports of fire. Additionally, there was one report of a minor burn injury.
Hoover first learned of a vacuum cleaner switch on one of these units overheating and melting in April 1999.
Federal law requires firms to report to CPSC immediately (within 24 hours) after obtaining information reasonably supporting the conclusion that a product contains a defect which could create a substantial risk of injury to the public, presents an unreasonable risk of serious injury or death, or violates a federal safety standard.
These Hoover Self-Propelled Upright Vacuum Cleaners are plastic, upright vacuums with the brand name �Hoover� and words "Self Propelled" printed on the front of the product.
Only those Hoover Self-Propelled Upright Vacuum Cleaners manufactured between May 1998 and November 1999 are included in the recall that is the subject of this penalty.
Jun 11, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
1,292 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
