posted by Jaymz on Jul 31, 2007
I have pretty old Emerson Quiet Kool wall unit that is dripping water into the house. I've read that i need to clean the drain plugs. How do i access the drain plugs?
Solution #1
posted on Aug 05, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem.
email the pics to eyg2181@yahoo.com
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Emerson Quiet Kool 14LW22K Air
Email this problem
Email this problem
Can you Help with these Air Conditioners problems?
Air Conditioners
water dripping from ge zoneline...
there is water dripping from ge... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
