Question about Channel Master 9521A Remote Control
Rotor not turning antenna
We just installed our new antenna and rotor today. We have the channel master 9521A as well as a channel master antenna. Everything appears to be connected properly. When we first powered on we performed a synchronization. We then used the up control on the remote and went through up to 360, the picture got better and then worse...as we expected, we just wanted to see if it got better yet. We then used the down button to go back where the picture had been the best and the antenna is no longer turning. I went back on the roof and opened the cover on the rotator and had my husband operate the base unit, I can hear a soft buzzing sound when he is asking it to move...but there is no movement. It is currently about 5 degrees out, could this be a factor? What else can we check? We hope to get the Superbowl tomorrow. Please help! Thank you for your time! Debi
  • Debi Scofield Feb 01, 2009
    How do I know if my rotor has a brake and where do I locate it?
    Sergeant:
  • 227 Answers
Most rotors have a brake, if yours has one, you have to hold the brake down then rotate.
Posted on Jan 31, 2009
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
Cannot get NBC on my channel master
Your signal strenght is too weak either try moving the antenna to a different location. If that doesn't work then you may need an outside antenna. The link below will tell you what stations are available at your address and what type of antenna is necessary.. TV Fool
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Cruzer tv antenna
Antenna rotators used to be available in the US but are practically non-existent today.
Nov 11, 2013 | Televison & Video
All of a sudden we can't pick up not one channel
Perhaps your tuner is bad. Have you tried reprogramming after you bought new antenna?
Feb 25, 2013 | Channel Master 3020 Large UHFVHF Antenna
Screen on tv just says no signal
When installing a new antenna, a TV will often need retuning in order to operate with the new antenna.
Using your remote, access the TV's menu (settings as oppose to TV guide) and you should be able to access a tuning menu, this may be located in Picture, or have its own section.
Select the setting for automatic tuning and you should find that the TV uses the new antenna to find its channels.
Aug 23, 2009 | Televison & Video
NEw TV antenna fails to capture all local channels
Dear Shoostar, 6:55 EST (USA)
It may be that those stations are only broadcasting in analog for now and since your using a digital converter the signal can't be read.
Did you try using the old antenna to get those stations?
If this is the problem you could use both antennas with a switch when you want to change channels for now until they all go digital.
I once used two antennas and a 4-pole switch to get Philly & New York from Jersey instantly back in the day.
I didn't like waiting for the antenna rotor to turn into place!
Hope this is helpful.
jack
ac2c3d4.jpgPlease Rate This!
Feb 09, 2009 | Leadtek Televison & Video
Locking digital channels
UNFORTUNATELY THE ONLY WAY YOU WILL GET BOTH IS WITH A SECOND ANTENNA. IF THE SET DOES NOT SEE THE SIGNAL IT DOES NOT LOCK IT INTO MEMORY.
Dec 10, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Channel Master 9521A Remote Control Logo
1,234 people viewed this question
Top Channel Master Televison & Video Experts
Electro Med Services...
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
