Question about Janome 1017 Mechanical Sewing Machine
Putting bobbin back
I do not have a manual to show me but the needle jammed and I took the Shuttle Race apart. The needle is free but I am not sure how to get it back together. I need to put back the part the bobbin sits on and the ring on top of that but not sure how it is to go back in. Thank you so much I borrowed this machine and want to return it back in working order.
    Scholar:
  • 69 Answers
You need to set the hook (1/2 moon shaped object) in first. That sits inside the circle. The round race sets in over top of the hook, a lot of times there is a pin or slot that has to match up on the race. Then slide the little arms back into place and you are all set.
Posted on Feb 09, 2009
Singer Futura XL-580 thread tangles on underside.Machine makes a loud "clicking" sound.Was doing free motion quilting and got a jam. Changed needle,changed bobbin,and rethreaded both top and bobbin.
Sounds like there might be some thread stuck in the bobbin shuttle area. Refer to the users manual for your machine to see how to disassemble the bobbin shuttle and race to check for thread. It would be a good idea to put a drop or two of sewing machine oil on it while you have it apart.
Aug 21, 2017 | Singer Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Hi
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Mar 16, 2009 | Baby Lock BL1556
Shuttle
The bobbin should be placed in the shuttle, with the needle at the top end travel. You can watch the shuttle move as the hand wheel is turned.
Jul 09, 2008 | Sewing Machines
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Dec 17, 2007 | Kenmore Drop-In Bobbin 505S-21BH...
Janome 1017 Mechanical Sewing Machine Logo
187 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
