Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Dishwasher spray arems not working, please advise your solution. Thanks
  • 1 more comment
  • Earl Apr 13, 2008
    Will fill with water, but wont spray or wash, after cycle it will pump out water
  • Earl Apr 13, 2008
    Will fill with water,wont wash or spray,then pump water out
  • wchambers Aug 19, 2008
    I have a whirlpool quiet partner 1
    The top rack is always dirty
    The bottom dishes are clean ....most of the time
    Please help
    Thanks
    Wendy
    President:
  • 331 Answers
Low water level. Either the inlet valve has trash in the filter screen or you have a bad valve. To check/replace you valve... turn the HOT water off underneath your kitchen sink. Then remove the kick plate and look under there. You'll see where the water line hooks up to the valve, remove the water line (probably a copper tube, but may be flexible stainless steel). Then remove the 2 screws that hold the valve to the frame and let it drop down. Remove the wire harness off the valve. Then use needlenose pliers... see that rubber tube that's connected to the valve? Squeeze that clamp and slid it back, then remove that tube. Now the valve is out. Now that you have it in your hand, look where the supply water comes into the valve... that 90 degree 3/8" fitting. There are 4 screws holding it to the valve. Before you remove them, TAKE NOTE THE DIRECTION OF THE FITTING. Now remove the screws and lift that section off. There you will see the filter screen. If it's clogged, it won't allow water through. Pop it outta there with a knife tip, clean it thoroughly and reinstall it. Rebuild the machine and turn the water back on. Check for leaks! Job time= ~1 hour
Posted on Aug 01, 2007
  • Tracy Farrell
    Tracy Farrell Aug 01, 2007
    If there's no trash in there, you'll need a new valve. The part number is #8531670 and sells for about $40.00 at your local appliance parts store.
SOURCE:
Bush Customer Service
You should be able to hang it anywhere inside the dishwasher. Try to pick a spot where the water spray will hit it.
Also make sure the location does not interfere with the spray arm movement as it spins around.
Nov 13, 2013 | Televison & Video
Hello my dishwasher is not cleaning the dishes properly and has undesolved powder in the dispenser.The plastic rack has snapped in some places and tends to sag There is a chalky residue on all utensil...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 15, 2011 | Whirlpool Dishwashers
My dishwasher doesnt get the top shelf clean and doesnt seem as though water is even getting to the top. the bottom is marginally clean and the utensil rack on the door doesnt get wet at all. any advise...
Dishwasher
How to Buy
heatman101
Jan 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I see residues of the soap after our wash. we usually use fast eco or just fast. if heavy we go normal eco or normal. Is it the soap were using or the FP has a problem. this just started with either the...
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Jan 04, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
It appears that water is not running through the dishwasher or that the sprayers are not working correctly. There doesn't appear to be a clog. However, I did find a round rubber "washer" (I think that is...
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Aug 27, 2010 | Hotpoint Dishwashers
When my dishwasher has finished its full cycle all my glasses are cloudy and cups tasts like they have a salty residue on them, if i rinse them under the cold tap there fine please advise
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Feb 04, 2010 | AEG 18 in. Favorit 64800 Free-standing...
Water Stayed in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
DISASTER! PLEASE HELP. WOKE UP THIS MORNING & DISHWASHER MELTED!!!
Amsanta, sounds like something got hung up on the heating element, stopped the lower spray arm and things started to melt. The lower spray arm, part number, 154414101 is easy to change out. There is also a lower spray arm support 154294101, don't know if you will need that. I believe on your model the lower spray arm just snaps on. There is a tab on the filter screen that will rotate to unlock and the filter screen will lift out. Now the lower spray arm support is accessable. If it's less than a year old, you may be able to get it fixed under warranty. Catriver.
Jun 09, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidare Dishwasher/rolls around
Nick, check the spray arms themselves to make sure they are not clogged, cracked or split. You have a seperate wash and drain motor on this model. It could be the filter under the lower spray arm is completely clogged with food gunk. You would have to remove the spray arm and get down to the filter. The wash motor itself has a small impeller on the end. It may be broken or the motor itself is bad. You would have to pull the dishwasher, the wash motor comes off very easily with just a couple of screws and you can examine the impeller. Catriver...post back
Oct 03, 2006 | Frigidaire 25 in. FDP750RC Free-standing...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
123 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
