Question about Denon Audio Players & Recorders
TV has no picture but has sound
DVD mode work fine. I can switch to that and watch a dvd just fine.
But to my comcast dvr it won't work.. i have an optical sound connection which i have set up correctly in Audio in options and the audio works fine. I have component cables hooked from the dvr to the AVR-987 and i have gone into video options in system setup on the denon recieve and set component sound on the TV setting to RCA1... i have it plugged in to a spot calle component 1 on the back... i can't figure out whats wrong.
    Scholar:
  • 93 Answers
Did you say you went in to DVR set-up and checked the component out audio option? I have had similiar problems with motorola dvr boxes and once I was able to enable audio output option the dvr digital output was fine. Find the manual for the model dvd and this may cure.
Posted on Feb 01, 2009
Everything was working fine, then the sound quit working when we play the DVD player. Switch back to TV-DVR mode and sound is fine. Change o DVD and it goes silent. We have to turn up the volume on the...
please try to find new firmware for this model, I guess it is HDMI version compilable problem. maybe after update firmware could fix your problem
Mar 17, 2011 | Yamaha HTR-5560 Receiver
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Panasonic 42" connected to comcast dvr, and dvd player
To solve need more info if this is still a problem.
Is your comcast dvr connected directly to the tv, and also the DVD connected directly to the TV?
If so then you will need to change the input selection on your tv remote to determine which inputs these devices are connected to.
If you are connected differently, please post how your devices are connected.
Dale
May 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
176 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
