Can this be fixed
I have a kitchenaid top load super capacity washer,6 years old.It will not agitate or spin makes a grindind sound.Feels like the drum inside is off the holding{if there is such a thing}.I have checked to make sure there is nothing caught around the agitator inside .The machine worked fine on first load no problems or odd sounds.Help have 4 kids!!!! Is this something worth fixing, can I do it myself?
  • Washing Mach... Master
  • 8,220 Answers
It is faily easy to fix. all you need is the part..Can this be fixed - b9ee9bf.jpg
You flip up the controls and remove the cabinet. The pump and motr come off easily. These web pages really give a good explanation:
http://repair2000.com/coupling.html
http://appliancejunk.com/motorcoupler.pdf
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
Posted on Jan 31, 2009
  • Dan Webster
    Dan Webster Jan 31, 2009
    Top loader blues
    Use a screwdriver to remove the screws holding down the control panel,then swing it upwards.
    Pop the s clips in the rear and remove the lid switch disconnect.
    Tip the case forward and remove it.You will now be able to repair the
    washer!
    The lid must be closed for spin. The lid has a striker in it that
    pushes against the lidswitch arm. This switch allows for spin IF the
    lid is closed. The switch may have failed. Mechanically the striker may
    be broken or the actuator arm may be broken.
    here is a broken lid switch
    You can test the switch. If you have a meter. If not you can
    simply bypass this switch. In my left hand here is the lid switch male
    plug which I have removed from the lid switch harness. If I wanted to i
    could simply place a jumper between the 2 outside wires and the washer
    would spin.
    Do not leave it bypassed if you have small children or braindead brother in laws.
    A 3 piece drive coupling
    NOTE: newer models have the screw hidden
    Here is a view of the washer with the case removed.
    To get to the broken coupling
    remove the pump first then
    the motor,both are held
    together with quick clips.
    pictured here is a broken drive coupling.
    Line up the new part and replace
    the motor, pump, and
    case in reverse order.
    NOTE:
    This looks hard but if you take
    your time it is easy enough to save you big bucks!
I have a GE, 4 to 5 years old, Super Capacity WJRR4170G1WW. When it agitates, the drum goes back and forth with the agitator. I though it should stay still. Please advise.
sorry to say you have a very expensive to repair problem ):
the transmission has a brake built into which is suppose to hold the tub in place during the agitation cycle and then release on the spin cycle to spin. the brake isnt engaging and the only fix is to replace the transmisson which is very expensive.
it may work for awhile then as it gets worse and the tub moves more during the wash cycle water will slosch out of it all over the floor,sorry to break the bad new
Jul 19, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
During spin cylces very load noises----bearings gone less than three old got estimate of 4-500 to fix does that sound right?
Yes, that is a good price for a main bearing repair. I wouldn't recommend it. I would buy either a whirlpool top load washer with and agitator ( we are doing to many repairs on the wp washers without agitators), or I would buy the super capacity front load duet. You will save more money in the long run with the front loader. Both of these have been the best washers built in the last 30 years. Good Luck, Appliance Specialists
Dec 15, 2010 | Kenmore Oasis 27042 Top Load Washer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
Oct 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
My kitchenaid top-load washer will not spin with a heavy load.
this will sound odd to you, but having done this for some time, i would bet there is something between the basket and the tub. sound impossible, but sometimes thing so get in there.......like lighters! you have to take the agitator out, get a speacial spanner whench to remove the nut holding down the tub(maybe $20 buck) then pull the tub out and see whats in there.
Nov 11, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
