Question about Acer Aspire 4315 Notebook
My Acer Aspire 4315 screen flashes on and off
My laptop screen will flash off randomly and then right back on again. It looks like a power issue, but it happens when it is unplugged as well as when it's plugged into the outlet. I have had this laptop for less than a year. Help?
    President:
  • 1,223 Answers
It is the lcd inverter that cable which carries signal from pc to lcd it gets distorted but u will see if u touch or move ur lcd postion it stops
Posted on Feb 20, 2009
I cannot get my acer aspire 4315 to AC power up. new batteries are ok. i have changed the power jack but no difference. please help
Check the light on the AC adaptor when plugged in to the laptop. If it is flashing, it indicates that the power is being "spat back". That is, not completing the circuit. Means that you have a fault in the charging circuit. I'd check for burning around the contacts where the DC port was soldered onto the board / or if the plug type, check the socket on the mobo is not damaged and is firmly soldered on.
After that, (if not already done) check the output voltage of the adaptor with a multimeter, might be a simple failure of the ac adaptor, even though it looks ok
Mar 20, 2011 | Acer Aspire 4315 Notebook
Acer Aspire 9301AWSMi , AMD Turion64 MK-36 2.0 Ghz, 512KB L2 cache, Nvidia GeForce Go 6100. PROBLEM: Black screen on start up, Power button green light on and only HDD led blinking random. and that it...
I've looked at this and sought advice from our Network systems and It people and I think the issues lies with the Graphics chip, or more probably, there may be an intermittent short in the power circuit, as the random flashing of the light is giving no clear error message
Jan 25, 2011 | Acer Aspire 9301AWSMi Laptop Charger...
Restore to factory default
Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 26, 2010 | Acer Aspire 4315 Notebook
My acer aspire 4315 laptop screen goes dark
ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
http://blog.shimpossible.com/2007/07/18/white-screen-of-deat­h/
Mar 05, 2010 | Acer Aspire 4315 Notebook
My acer aspire 4315 laptop screen goes blank every now n then. if i just adjust it or tap it ,it comes back again.this is there for quite some time.my dealer isnt halping me.says some loose connection with...
The dealer may be right, there are two possibilities. One is your lamps or the lamp power supply is faulty, to confirm it is tha lamps, when the screen goes blank shine a flash light on the screen at an angle and see if you can any images on the screen, if you do it is the lamps or the lamp power supply, you need to take the screen apart to get at them.
If no images it is the connection to the video inputs, to fix that you have to take the computer key board etc. Chech the connections.
From what you say, it sounds more likely the lamp power supply connection. you may need to get a new cable.
Mar 01, 2010 | Acer Aspire 4315 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
Jan 19, 2010 | Acer Aspire 4315 Notebook
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
White screen
it might be the lcd inverter problem u ppl are facing go for the warranty if u have one
Feb 12, 2009 | Acer Aspire 4315 Notebook
Screen on laptop goes white
Maybe cuz of screensaver. disable the screensaver.
Jan 15, 2009 | Acer Aspire 4315 Notebook
Acer Aspire 4315 Notebook Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
