Question about KDS Valiant 6380iPTD-01 Notebook
Ign. tries to light although the tap is off.
We have a gas boiler that lights up when you run the tap.
But it is "clicking" to light up when the taps are off and there is no gas flow.
Can the 3 way gas tap be replaced with two independent cut off valves by a GAS Safe installer?
sorry that is something you need to check with the gas company about .
Dec 01, 2016 | Water Heaters
How do you correctly place logs if no direction in gas fireplace?
If you have to tap the gas valve one or more of the diaphragms/springs in it are sticking, which would account for no difference between low and high.
May 02, 2014 | Intertherm Heating & Cooling
Pressure gauge reading zero
Hello Mark
First of all turn on a hot water tap and keep it running whilst you check to see if your boiler is firing up, if it is not then try to restart it, you should hear the flame if its running, turn your tap off then just stand by the boiler for a few minutes to see if the pressure gauge starts to rise, if it doesn't rise you will never get any hot water, you will have to add some pressure to about 1 and a half on the dial, to do that is simply turn on the water valve in the bottom of your boiler and watch your pressure gauge rise to about 1 and a half then firmly turn it off again, it looks like a small tap like the one at the back of your washing machine pipe, it's ok you will hear the water rushing in, now with your gauge at about 1 and a half and your boiler running your water will get hot
Oct 23, 2012 | Water Heaters
Boiler not cutting out
hi thermosat or the water valve is staying open allowing the gas to flow at full rate when water is off hence the steam , boiler is very broken call a gas fitter to fix it .
May 06, 2010 | Heating & Cooling
Bosch water wizard 16 - gas still runs after water tap turned off
Sounds like a flow sensor may be bad. It may be registering flow when there is none and it sending signal to ignitor and gas solenoid that there is.
Apr 04, 2017 | Bosch Water Heaters
How do i refill ny worcester junior 24i combi boiler? as i cannot get the pilot light to light
Two types dependent on age
Early - in the mains water inlet pipe there should be a service valve/tap which when turned on will refill [it is close to or part of the fill loop - a metal braided flexible pipe
Later - underneath there is a hole for a plastic tap [supplied with boiler] to be inserted [usually just right of center] Insert and turn 90 degrees then close to it another small knob or 2nd tap which when turned [same action as a basin tap] will refill. If the first tap is not inserted properly water will drip out past its seals
For both Refill to about 1.5 - 2 bar and turn off
For the later as above but also remove the 1st tap
Mar 14, 2010 | Water Heaters
Boiler works great bottom will not light
fuel valves are most likely faulty. Most common problem in these.
Nov 13, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Vaillant boiler (VCW GB 221) not heating up water or heating although the pilot is lit. Pump is heard working okay but there is small drips of water underneath boiler. Any idea's?
The movement of the diverter valve is critical on this appliance, and is located on rear right of the boiler, when hot water is turned on, theres are two microswitches, which must break (they both close in Central heating mode), if pump is running, it is recognising the hot water demand, check microswitches are breaking, if not, it tends to be a defective servo valve (located above the water valve), or a blocked/ restricted control line (small copper tubes which connect into the servo valve)
Nov 29, 2008 | Heating & Cooling
KDS Valiant 6380iPTD-01 Notebook Logo
23 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
