Question about Sony Handycam DCR-TRV350 Digital Camcorder
My xp machine is not recognizing the dcr-tvr350 handycam
Installed drivers for usb but imagemixer is not free. any suggestions?wont sony vegas work the same?
When I try to capture a video into the imagemixer software, it says it does not recognize the camcorder.
lets see if it's a software issue or not.try to use windows moviemaker as your video capturing software instead of imagemixer. if issue is with imagemixer alone, you may want to uninstall and reinstall and update the software.check website for update: http://support.d-imaging.sony.co.jp/www/disoft/int/pixela/imx/dl/index.html and download the free update for imagemixer ver.1.5 for sony.
if still it's not recognize we can isolate the issue with the camera or connection. if your using usb,make sure you have the usb driver installed properly.you can download the device driver at this website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV350 and make sure you don't have the camcorder connected during the installation.also have the usb stream setting (under setup menu) set to on (see:p.221 of your manual). after that the camcorder should be recognized. if your link connection (ieee1394 or dv) it should be a plug-and-play connection. better check computer connections and connected device in device manager screen to see if the cam is listed as an unknown device.if it does, you can be sure nothing is wrong with the usb cable. it can be a connection.issue.try diff ports if available (usb back port at the back is recommended for use, that is directly connected to the motherboard) and check. if the cam doesn't show or you don't have any indication that it's connected.try using a diff usb cable.if still doesn't try using a diff compatible PC.use same procedure.if' it's still the same, unit may require service.hope this helps.thanks:)
Apr 15, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
How do i delete videos off imagemixer page
run the handycam utility CD and install the HDD Handycam Utility driver/software. Then put the camera on the base, plug it into your computer via the usb cable. Turn the camera on. Wait 5 seconds, then hit the button on the base. You will here your computer recognize the driver and ask you what to do with it. Close that. Then open the HDD Handycam Utility probram. It will prompt you to import the video/camera files. You will find a delete option there, too.
Aug 26, 2009 | Sony Handycam DCR-SR42 Camcorder
Usb driver for sony dcr pc55
Compatible Operating Systems
  • Windows® 98 Second Edition
  • Windows® Millennium Edition
  • Windows® 2000 Professional
  • Windows® XP Home Edition
  • Windows® XP Professional
Important:
  1. DVD Handycam and Hard Disk Drive Handycam are NOT supported by this driver.
  2. DV streaming function in DCR-PC1000/E is NOT supported by this driver.
  3. This driver does not support USB Streaming under the Windows 98 operating system.
  4. To ensure that no other program interferes with the installation, save all work and close all other programs. The Taskbar should be clear of applications before proceeding.
Handycam® Standard Definition Camcorder - DCR-TRV285E
or in HERE
Nov 20, 2008 | Sony DCR-PC55 Mini DV Digital Camcorder
Sony dcr-trv140 video download
You have to plug your camera into the computer, put it on VCR mode, go to the menu on the camcorder, select setup menu (4th down), usb stream, turn it on. I cannot believe it was that easy.
Jan 29, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony Handycam dvd201 and iMac G5
Looks like a rip operation. Close the DVD session and try http://www.macupdate.com/info.php/id/14414
Sep 14, 2005 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
178 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
