Question about Magic Chef CTF2125 Top Freezer Refrigerator
Puttin refrigerator lock on freezer door
My husband was putting refrigerator lock on the freezer door and when he went to put the screw in a bunch of air starting escaping.The door opens on the right side. Its a magic chef refrigerator with the freezer on top. The fan seems to still be working but we have no idea what it was escaping from the side of the freezer or if it can be fixed. I hope you can help us and any information you can offer would be greatly appreciated. We have 2 Autistic children and we have to keep the freezer and refrigerator locked.
Thanks for your time and help if you can.
  • 410 Answers
Unfortunatley when he drilled the hole in the cabinet he accidentally drilled a hole in the freon line this is not repairable you will have to replace the refrig. sorry for the bad news.. peyton
Posted on Jan 31, 2009
How do i manually defrost an LG French door, bottom freezer, refrigerator?
same way but use a fan as well to blow the warm air into the freezer
Apr 24, 2017 | LG Refrigerators
Plastic door shelves fall out
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Aug 26, 2014 | GE 21 cu ft Top-Freezer Refrigerator White...
How can I get my freezer door handle to stay on?
If the screws are still good, put some "lock tight" on them and tighten. This should fix the problem
Jun 17, 2014 | Amana AFD2535DEW - 25 cu. ft. French Door...
How to remove bottom (freezer) door on my subzero refrigerator/freezer
With the door closed. Remove the cover over the bottom door hinge by removing the two screws holding it in place. This also allows the door closing mechanism to be removed. Rotate the door closer away from the refrigerator and slide straight down. Now open the freezer door. Take a pencil and mark around the hinge on top of the freezer door so you will know where to put the hinge back in place later. Remove the three large hinge screws and two small shipping screws. This will release the door on the top. Rotate the door away to get free from the hinge and pull the entire door straight up.
Dec 08, 2013 | Refrigerators
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Putting refrigerator lock on freezer door
he may have punctured a freon line you will know for sure if it stops cooling.
Jan 31, 2009 | Magic Chef CTF2125 Top Freezer...
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Admiral side by side Freezer door problem
Hi , let the freezer incline put pieces of thick cartoon on front legs of the freezer so that the door will shut , the door contact magnet are weak. check also the screw and bolts of the door might lose.
Jan 16, 2008 | Admiral 26 cu. ft. Side-By-Side...
Magic Chef CTF2125 Top Freezer Refrigerator Logo
198 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
