Question about AOC LM720 17" Flat Panel LCD Monitor
I have a problem vith a monitor aoc lm720a
Ven ai start my monitor i dont have any control on the meniu the only fing the monitor due its changing the colors like she is in a service mode first ist red after gren and last blue .someone now the problem?
  • exbayboy Mar 13, 2008
    i have the same problem plug it in the vga plug & its black take it out & goes through a test pattern thing whats coursing this is it the lead . mine is the 520
    Problem Solver:
  • 15 Answers
Try to connect another monitor to verify the problem is related with your video card or the monitor itself
Posted on Aug 01, 2007
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
I need a power cable for an LM720a monitor
There is a new one at Amazon.com.
heres the link.
http://www.amazon.com/HQRP-Adapter-Monitor-Replacement-Coaster/dp/B0025UAFYE
Aug 30, 2010 | AOC LM 720 17" Flat Panel LCD Monitor
Hi there. Does anyone have a mannual how to use the control panel on the bottom right hand side of the screen? I've just brought this one today and the User disk that came with has nothing on it! many...
You dont need the driver disc, windows will install any driver that is needed, the disc usually contains colour temperature profiles if needed for certain graphical programs.
usually you just press the menu button and go thru the options, modern pc's and monitors dont need much, if any adjustment, but if you do want a little play around with the controls, look here. http://www.retrevo.com/support/AOC-19LVWK-Monitors-manual/id/575bh239/t/2/
Aug 20, 2010 | AOC 19LVWK LCD Monitor
MY PC MONITOR AOC LM720A HAS A BLACK SCREEN WITH THE MESSAGE OUTPUT NOT SUPPORTED CAN YOU HELP
if u are changing ur old monitor to new u may face problem ,
press F8 when the system starts and select the safe mode option and login admin mode change video settings resolution(control panel/display properties) into higer like (1020 pix) and if it visible give yes and restart
May 19, 2010 | AOC LM720 17" Flat Panel LCD Monitor
Web cam not working. I might not have the connections correct. Can someone help?
webcam must be activated by enable them
1. open task manager by right clicking on taskbar. services, ggo there and fing term containing webcam or VCM, start and enable it
Dec 27, 2009 | AOC Computers & Internet
Hi, I have an AOC LCD Monitor LM720A and I can't get it to turn on, ie a power issue possibly, I have changed the fuse and there is still no life, any help would be greatfully appreciated. Thanks Tony
anthony_salt, If the fuse you replaced is still good, then I would first check the "switch-mode-power-supply" for bad electrolytic filter capacitors. By the way, was the original fuse bad? I also highly recommend you pay a visit to YOUTUBE, search out and view the longer vid clips of lcd monitor disassembly and lcd monitor repair. FYI try a website run by another fixya guy nickname is "buddymc" and the site is www.ccl-la.com/badcaps.htm They refurbish (rebuild) lcd displays of all kinds and all manufacturers. You can also check out these other sites FYI. www.lcdparts.net , www.badcaps.net I hope that this info steers you in correct direction. Good luck guy. 12fixlouie bye
Nov 09, 2009 | AOC LM729 17" LCD Monitor
No display
Try Unplugging the monitor and plugging back in again,,,you dont have to shut the PC down to do this,,,if it starts backup,,,then good... if it doesnt,,then you need another Monitor.
An LCD monitor is better for your eyes anyway.
Jan 19, 2009 | AOC 1556NB 15"
AOC 17" Flat Monitor (silver)
Hello all.I had 2 AOC monitors with this kind of problem also and figured out the problem with this kind of monitor. All you have to do is to unscrew the monitor and get the control control switch buttons on its circuit board. There are four switch button that control the monitor with four pins each that attaches to the circuit board of AOC, another option is to replace the switch button with a brand new  control switch button which can be bought to your local electronic shop. Now i had no problem with my AOC monitor because i literally removed those switch control buttons from its circuit board.
Mar 03, 2008 | AOC CT720G 17" CRT Monitor
Lm720a 17" monitor switches it's self
try to resolder all lost contact on flyback transformer..............................
Oct 11, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
AOC LM720 17" Flat Panel LCD Monitor Logo
269 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
