Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
I have a Bosch WFL 1660 Front Loader which will not spin at all.
Machine is otherwise working ie all lights come on, water is taken in etc and then it clicks as though the barrel is going to turn but it doesn't move.
Have cleaned out intake filter and pump filter.
Any further suggestions much appreciated.
S
  • surosa Feb 13, 2009
    Thanks for your suggestion. Turned out to be the bushes(?) which were worn out and needed replacing. All is now working well.
  • 20 Answers
You have bad Motor control board.
Posted on Feb 10, 2009
Hi My Bosch Classixx Washing Machine wont Rinse or Spin Help! Washing Machine still has water in it!
you should have a cover that will come off ... on front bottom... then u will see a filter housing lid unscrew ...have towels a tray ready as water will come out.... check filter when out and see if theres any foreign objects inside ie money ect .. put back together hopefully your happy .........
Feb 27, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Just bought the Bosche Axxis front loader. When the spin cycle kicks in, the machine wobbles/shakes/wanders VIOLENTLY from side to side. Is it the installation or the machine?
I bought the Bosch 8Kg washing machine on 8th Feb, I had the same problem.
Read installation instructions, you need to remove transport safety nuts from the back.
Feb 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 1660 Front end loader washing Machine , Washing Cycle fine , Into spin Cycle , there is a huge knocking sound , and then the Circuit breaker supplying the apparatus trips ???
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Feb 28, 2009 | Bosch Washing Machines
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
570 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
