Question about Kodak EasyShare DX4530 Digital Camera
Battery compartment door
My dx4530 fell and broke the little plastic lip that holds the battery compartment door off of the door part. I called kodak and purchased a new door. I need to know how to install it. please help if you can.
  • Sam daher Jul 31, 2007
    I guess i need to wait to see when the part arrives. it may be real obvious
    Thanks for your reply.
    G.
    Genius:
  • 2,985 Answers
Only by examining the camera your self will you find out If you managed to purchase a part- perhaps an installation diagram is available from the same source.
Posted on Jul 31, 2007
SOURCE:
I got a dx4530 w/easyshare Dock II. from a friend of mine. He had been using AA batteries and it worked fine. I went to Best Buy and bought 2 Ni-MH batteries and put them in the camera. I then put the...
In the Kodak cameras of that vintage the original 3V rechargeable battery was made of 2 regular AA rechargeable batteries and a special piece of plastic that pushes some microswitch in the battery compartment. If this piece of plastic is missing, the dock would not charge the batteries. You either need the special CRV3 battery or to charge the normal AA rechargeables with a separate charger.
Sep 18, 2011 | Kodak EasyShare DX4530 Digital Camera
The battery door on my Kodak EasyShare DX4530 zoom digital camera will not stay closed. It is possible to replace the door?
You can buy the replacement part from
http://uscamera.com/5e8407.htm
so I would assume replacement is possible.
Jun 20, 2011 | Kodak EasyShare DX4530 Digital Camera
Broken battery door on a Kodak DX4530
yeha if u go to like a place that only deals with camera's and stuff thats the only way like specialist
Jan 15, 2009 | Kodak EasyShare DX4530 Digital Camera
FE-140 Battery compartment door broken
you could try and put all the info about your camera in to google search..or the same on ebay.
Oct 27, 2017 | Olympus FE-140 Digital Camera
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
My easy share CX4530 won't
Mine did that and all it was is the door that holds you batteries in gets weak over time. If you hold or squeeze the door closed and it does not happen then you have found you problem. Clean the contacts and try to "bend" them outward to get a cleaner and tighter connection.
Apr 12, 2008 | Kodak EasyShare DX4530 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
KODAY DC3400 BATTERY DOOR BROKE
Easy Fix-
I had the same problem. Place the camera upside down with the battery door to your right. There is a plastic plate with the eject switch to the left. It has three philips screws. Get a jewlers screwdriver (Any hobby store, Harbour Freight, etc.) Take out the three small screws. Don't lose them. Get a razor blade and pry up the plate in the line just to the right of the top right screw. Only pry up about an 1/8 of an inch and only that corner not the whole plate. Then you can slant the new battery door so that the top part goes to the left under the plate and then straigten it out so that the tabs seat in the grooves. Repace the screws. Voila.
Good Luck,
-Joe
Aug 14, 2006 | Kodak DC3400 Zoom Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
159 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
