Question about Linksys Wireless-G WRT54G Router
Lose internet connection
I have cable internet and recently added a Lynksys 802.11g router so my son could hook up his new X-box 360. Most of the time we can use the internet with no problem but sometimes it will lose connection. We did not have this problem before the router. I can regain the connection by unplugging the cable modem and then plugging it back in. A time or two I had to unplug the router as well to regain the connection. Any ideas?
  • 928 Answers
Normally this means that you have to update the firmware of the router. If you just recently purchased it you can call 8003267114 so that linksys can walk you through the upgrade. If your not under warranty message me and ill give you a walkthrough.
Posted on Jan 31, 2009
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
My pc has room for one ethernet cable and its already taken to a router box. i have no idea what its for but now there seems to be nowhere to hook up my 360. i want to hook up for xbox live and netflix....
Simply put
You need to plug your xBox 360 into the Router not the PC.
The Router should have more than one ethernet slot. (That is what is generally meant by the term Router).
1. Plug one end of the Ethernet cable into your xBox 360.
2. Plug the other end of the Ethernet cable into an available slot on the Router.
If your Router is constantly connected to the Internet then this should solve the problem. If it is not, then connect to the Internet via your PC and then when the internet is on the xBox should find it.
Hope this helps. Regards,
Feb 09, 2010 | Microsoft Video Game Consoles & Games
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Motorola sbvs220
Make sure that your router and computer are set to get their IP addresses via DHCP.
Either the router is not setup as DHCP server or your computer has a static IP address assigned which conflicts with the router settings.
Do you have cable or DSL service (in which case the router should be set to PPPoE)?
If you have cable service, just reset the router to factory default by pressing the reset button on the back for about 30 seconds.
Then go to your computer and
  1. Go to Control Panel -> Network Connections.
  2. Right-click your Local Area Connection and choose Properties.
  3. Scroll down and double click on Internet Protocol (TCP/IP).
  4. Make sure that all settings are set to Obtain ...automatically.
Click OK two times (the second time takes a little bit longer, because the settings are applied.
If you have any more questions or need help with the settings, just come back here and leave a comment - I'm happy to help.
May 29, 2009 | Motorola Computers & Internet
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Lynksys Connectivity Problem
occassionally, the wireless router needs to be turned off and on. The are some issues with regards to the stabitlity of these entry level wireless routers. What I do is put a timer at the outlet to reset it every morning. cheers!
Oct 16, 2008 | Linksys Wireless-G WRT54G Router
Have an Acer Aspire PC computer - trying to hook up a Lynksys nr041 router so can hook up another HP Notebook computer...not for sure how to do this and be able to use internet on both computers. Thanks...
Ok if you have DSL this router will NOT connect via PPPoE so no user name or passwords for dsl. But if you have a cable modem just plug the network cord from your cable modem into the WAN port on router... then plug the computers into the 1-4 ports on the router.. you might need to reset your Cable/Dsl modem after everythings hooked up.
May 02, 2008 | Linksys (NR041) Router
the solution buy another router you you can use other cp
Apr 14, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Wireless-G WRT54G Router Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
