Question about Toshiba Satellite M105-S3041Notebook
Display/light problems My toshiba satellite laptop is about 2 years now. It has encountered one problem, everything is working perfectly except for the display. The screen is totally black and this forces me to use another monitor. How will I resolve this so that my machine could work as usual?
    Champion:
  • 219 Answers
Sounds like a screen problem since you can use another monitor, I don't think it would be the graphics card...
Posted on Feb 01, 2009
Toshiba satellite c675 monitor light up but not displaying anything
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. you will need to aquire a toshiba manual for your laptop to help you fix these issues. here is the link for finding your manual Search
Aug 13, 2014 | Toshiba Satellite C675d-s7310 Amd E-480...
Screen is black but computer works perfect.
When this happens it means the back light needs to be replaced. The back light is a light bulb that lights up the screen from behind the LCD display.
Sep 07, 2009 | Toshiba Satellite A135-S2276 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
I have got Toshiba satellite L310 laptop. The current display drive is Mobile intell 4 series. the device mangaer says it works perfectly. I don't thing so where my system is no working perfectly with any...
Well I will try to help. Download your video drivers here and update your drivers.
Page does indicate that driver is an Intel Display Driver.
Let us know if this resolves the issue.
Thank you.
Mar 04, 2009 | Toshiba Satellite 310CDS Notebook
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Thankyou
Nov 26, 2008 | Toshiba Satellite A60 Notebook
NO PICTURE ON MY TOSHIBA SATELLITE #L305-S5885 DVD PLAYER OR WINDOWS MEDIA PLAYER, CANNOT PLAY DVD'S!
try to update your media player.if possible windows media player 11. If still it doesnt work try to check your direct X installed components. Try to update it also. next try to check your display driver settings maybe your display driver isn't working. check it by running the run command and type dxdiag to check your computer system go to the display settings and check if there are any installed driver.
Oct 11, 2008 | Toshiba Satellite A135 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite M105-S3041Notebook Logo
216 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
