Question about Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine
I have an old Singer 478 and I can't get the needle to grab the bobber thread. Is there a special trick for this one?
  • Meridian411 Feb 01, 2009
    I have the singer 758 and the thread is not catching the bobbin thread.  The hook moves but doesn't catch the thread.
    New Friend:
  • 186 Answers
When you turn the handwheel, does the hook move? If not the top gear on the vertical shaft is stripped and needs to be replaced.
Posted on Jan 31, 2009
Thread is bunching up and it locks. Now needle wont pick up bobbin thread.
if thread is locking up on tension post then its set too tight or is not threaded correctly , this can cause lower thread to miss too having top thread too tight , also ck for a bent needle this is another cause of missing lower thread
Jan 19, 2016 | Sewing Machines
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
Singer 6235 - needle not grabbing bobbin thread
Make sure of 4 things. One, that the correct needle length and diameter is being use in the machine. Second, make sure you are turning the flywheel the correct direction and third, and fourth, that you have the Bobbin inserted correctly and spinning in the right direction. when picking up bobbin thread.
Cheers,
Embroidery Services
San Diego, CA
Sep 19, 2017 | Singer Sewing Machines
I have recently bought Singer Quantum 9940 and I am not happy with the stitch. For zigzag stitch, I can see too much of the upper thread on the bottom side. This happens unequally: more on the right hand...
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
Feb 05, 2011 | Singer Quantum 9940 Computerized Sewing...
The needle hits the plate and doesn't go down to grab the bobbin thread reguardles of the needle position.
Sounds like a timing issue, Unfortunately it is not a do it yourself job. You need special tools and the training to do it right. Sorry, but you are going to have it serviced.
Oct 23, 2010 | Singer Sewing Machines
My bobber won't thread after my thread got stuck while I was sewing. Now it sounds as though my needle is hitting something. HELP!
your machine is out of time.if you are handy you can reset the timing between the upper and lower shafts if not take it to the a local shop.
Jun 26, 2010 | Singer Confidence 7467 Mechanical Sewing...
Singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Apr 23, 2009 | Singer 7436 - INGENUITY
Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Jul 05, 2008 | Singer 132QRFB Mechanical Sewing Machine
Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine Logo
365 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
