Question about Dell W1700 17 in. HD-Ready LCD Television
No sound dell 32in tv
While watching television, the sound just ceased. The picture is perfect, all of the cables were checked to see if they were in securely, and I went into the menu and restored the factory settings. Still nothing.
    Sniper:
  • 133 Answers
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Posted on Jul 31, 2007
No picture has sound on 32in combo proscan
Make sure the antenna or cable wire is firmly connected on the rear panel of the TV. Then click the Settings button your remote control and check if someone accidently selected "Picture Off" mode and undo that setting.
Nov 04, 2014 | Televison & Video
I put a new t-con board in a flu3232 polaroid 32in tv but still no picture?
Did you replaced the T'Con board with original number? In most cases, the LVDS cable [the cable that connects with T'Con to panel] too should be replaced along with the T'Con board. Try that too, if the T'Con board you replaced is with same part number. There is no more special adjustments should be done after T'Con replacement. If the board should work perfectly. Electro help
Jun 04, 2014 | Polaroid Televison & Video
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
Static & no picture from UHF input / Component Video fine
there is sinal interferences from laser products pc mobile transmitters or video games get high quality vcr and cable tv cables move or switch off any video games cd players energy saving lamps or pc and microwaves n motors like pumps change the position of installation of cable and antenna to avoid path of interference
Jul 18, 2013 | Sony KV-36XBR450 36" TV
My tv sound is schreeching
OK sounds like you have problem on your cable box connection or signal..Try to play a dvd to test. If the sounds fine on DVD you definitely have cable box prob.
Dec 10, 2012 | Dell U2711 27 in LCD TV
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
Receiving the sound but no picture on digital TV channels
If you are trying to watch HD TV through the tv and you are only getting sound, it is most likely because you would need an High Definition cable box. Hope it helps
Aug 11, 2009 | Samsung HP-S4253 Television
TV HAS SOUND BUT NO PICTURE
replace the H.O.T horiz. Driver Transistor.
comen problem with this set.
Jan 13, 2009 | Sylvania 6432TE 32" TV
Dell 32 LCD Flat Screen multiple problems
I have checked all the connections and replaced all the cables with the highest quality I could buy.  I think the problem is in the TV tuner itself.  I live in a MDU so I am stuck with a rooftop satellite/master antenna.
Oct 23, 2007 | Dell W1900 19 in. HD-Ready LCD Television
Dell W1700 17 in. HD-Ready LCD Television Logo
167 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
