Question about Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)
Reformat of external hard drive
Power failure has cused my 400g external USB Drive to lose partiton information as well as the MBR and MFT. I have software to recover my files from it, but would like to reformat the drive once recovered, I cannot find it in disk management but do find it in my computer but won't let me access it without the recover software. All I want is to reformat the drive and get it to work again, weithout spending $200 to have it recovered.
  • Michael Golding Aug 02, 2007
    Partition Magic removed thepartiti on problem ( or so it said) Now nothing reads and it will not even read now. Cannot even getnk ill disk to wipe it for me so I can start over withg the drive.
    Will try the hp solution next, but I am fearful about the flash aspect. The last time i flasheda Bios i had to replace the mother board. Hope I can be careful enough not to screw up the master drive and all it holds.
    DR. MIKE
    Brigadier General:
  • 6,966 Answers
Hi, You may want to try: 1. HP Utility Software (actually intended for flashdrives but I have tried it and it worked with my external USB drive)http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html 2. Partition Magic http://www.soft32.com/download_151.html (have used this likewise with no problems just don't forget to set in preferences your main drive as read only) Hope this be of some help and give you ideas. Pls post again how things turn. Good luck and kind regards.
Posted on Aug 01, 2007
  • Louie  Role
    Louie Role Aug 02, 2007
    Hi again,
    If partition magic was able to delete the partition,it will have first to re-create a partition before it can format the hard drive. Pls have you tried that function? Kill disk will not function on it now because it does not have a valid partition yet.
    Or you may want to try it using the Windows method that you earlier mentioned Start, Settings, Control Panel, Double-click on Administrative Tools, (Storage) double-click Computer Management, create partition, format to either NTFS or FAT 32.
    You seem to know what needs to be done, good luck again and I know you will be careful.
    Cheers
2 Suggested Answers
PCTServices
  • 120 Answers
SOURCE: Reformat Hard drive after power failure
Try this program http://findandmount.com/ it very well may fix your problem
Posted on Aug 02, 2007
WD1600CO32 hard drive not recognized or system wants to reformat
Your only option is to reformat. This happens when the MFT is damaged. MFT (Master File Table). Once you format the drive, download, install and run Recura and do "Deep Scan". You should be able to recover your files.
Dec 30, 2012 | Western Digital My Book Essential Edition...
If i reformat my external dont i lose my already saved data
formatting wipes a drive clean. so if you format your external then all data on it will be lost. I assume this is what you mean.
Nov 15, 2011 | Western Digital WD Elements Portable...
I backed up files from computer to external hard drive and when i go to use files from external hard drive it dos not read any of the files. How can i reformat the external hard drive with out losing the...
Unfortunately, it is impossible to reformat a drive and not lose the data that is stored on it.
I would suggest formatting the drive as NTFS if you are using Windows or HFS if you are using a Mac and then use the software that was included on the drive to backup your computer.
Be sure to copy the software that came ON the external drive to your computer before reformatting. If you are unable to find the software on the drive, you will have to buy the software from Memeo or contact Western Digital for assistance: http://www.memeo.com/choose_backup.php
May 08, 2011 | Western Digital My Book Essential 1TB...
Wont boot and says that no operating system can be found
Get a recovery disc for your computer (OS or a partitioning/utlity tool). You need to find out if you lost the MBR (the where is the OS information), the partition, or if the hard disc failed.
It's very likely that any repair attempt may reformat your hard disc. So consider a Live CD rescue tool and backing up if you haven't been consistently doing so. (Attach a USB hard drive or external optical drive for the backup data.)
Good luck and I hope this helps.
(who has a computer smart relative who reformatted the computer without salvaging the data to find out the hard drive was failing and that was why it lost the MBR the first time.)
Apr 17, 2010 | IBM ThinkPad A31 Notebook
Is there any way to reformat my drive without losing all my information?
Only by backing it up to another drive first. Formatting destroys information on the drive.
Apr 13, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Trying to reformat mini dell with no cd rom drive tried to boot from usb but comes up with No bootable partition in table what does this mean
Recovery discs have certain run procedures, flash drives dont. I would suggest you obtail or lend and external USB writer
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Space error
plz formate your drive through cmd after format its not working then your drive is fake space
Aug 30, 2009 | Western Digital My Book Essential 1TB...
Problem with seeing files on external Hard drive
What has happened is that your file system on the hard drive became corrupt becasue windows had not updated the MFT on the drive. THe MFT is a table of contents regarding whats on your drive.
What happened is similar to someone cutting out a few pages of the table of contents in a book that has a lot of pages.
Windows tried to fix this stupid programming method by asking people to always use the "safely remove hardware" button in the taskbar to force it to update the MFT.
In this case yur a victim of the Hard Discs MFT not updating properly probably because software was accessing the drive when it was disconnected from the machine.
You need to run chkdsk to have it rebuild your MFT.
http://support.microsoft.com/kb/315265 <-- How to perform Check disk
*NOTE: Remember to use the drive letter that the USB External is on.. Not just type CHKDSK. It will default to drive C to scan for errors. ex: c:\chkdsk g: (where g is the drive your external usb is)
If you get an error like "CHKDSK is not available for RAW drives.. see my notes below.
Beware that it will take a LONG TIME to perform this procedure.
If this doesn't fix it.. contact a data recovery specialist.. It's worth the cost. There are two types. Simple and Advanced.
Simple= recovering files your deleted with the delete button (fairly easy with the right software)
Advanced = recovering files from a hard disk crash or file system corruption. (Not easy and very time consuming)
Nov 04, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Samsung sp2004c drive failure
My guess is that your hard drive is corrupted. If you have any extra hard drives (external or internal), try replacing your current hard drive with that one, and see if that works. If it does, you may have to take your Hard Drive to a computer shop to have it recovered.
If that doesn't work, then something corrupted your operating system. I would re-install the operating system (reformat may not be necessary, but is always better than just a reinstall, although you do lose all of your information during a reformat), and then try.
Feb 10, 2008 | Samsung SpinPoint P120S (SP2004C) 200 GB...
Aug 02, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Computers & Internet Logo
151 people viewed this question
Top Smartdisk - Peripherals Computers & Internet Experts
Alun Cox
k24674
Are you a Smartdisk - Peripherals Computer and Internet Expert? Answer questions, earn points and help others
