Question about Toshiba (HDD2181) (hdd2181-50pk) 30 GB Hard Drive
Sir/Madam when i attached my external 30gb hdd via usb ide data cable with my laptop message appear "unrecognized device" how i solve this problem?
    Problem Solver:
  • 9 Answers
You need the driver for the device. If the HDD came with a disk you will need to install that beore hand. =) Hope this works.
Ed
Posted on Jan 31, 2009
External 3.5 inch IDE hdd encloser connected via USB is showing "device is not ready" when try to initialise it in the disk manager
Check the jumper settings of the IDE hard drive you have in the enclosure for compatibility in your setup. (Choices are Master, Slave and Cable Select).
Feb 06, 2014 | Computers & Internet
My Toshiba laptop wont download pics from my Canon camera - it used to be fine but wont do it now!
Does the camera appear in the device manager?
right click my computer select manage
on the left side select device manager
look on right side do you see your camera and does it have any ? or ! marks?
Aug 09, 2008 | Cameras
Toshiba 451c "can not find HDD data" message
Had the same problem and solved inserting and extracting the card a whole bunch of times and blowing hard inside the slot. You can also try using the rubber to clean the contacts of the SD. God luck.
Nov 22, 2013 | Toshiba Office Equipment & Supplies
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
Unrecognized
some proble was in USB socket of your external HDD...poor contact...
try to use another HDD enclosure to use with you HDD..
that problem occur due to pluging in and out several times...maybe the connector was damaged...hope it helps..
or try another PC again...some problems are not detected due to virus in PC...
May 25, 2010 | Western Digital Passport WDXML800UE...
How can I replace my 30GB ultra ATA EIDE HDD with
Purchase a solid state drive, 2.5" for laptops 3.5" for desktops (or use an adapter for notebook drives with a 2.5")
Connect your IDE cable (and power cable on desktops) to the drive, install Windows and you are done!
If you want to keep your existing data, get an external enclosure for the appropriate sized disk and use a program like Norton Ghost or Acronis True Image to clone the existing drive to the new one, then swap the two drives (SSD from enclosure to internal, other drive out to enclosure)
Comment if you need more information!
Feb 06, 2010 | HP 100GB Ultra ATA/100 EIDE hard drive -...
MK1637GSX from a laptop, trying to attach it to a desktop for data recovery. Wondering if its possible and if so, what parts I need to do so
Go to a computer retail store and ask for an IDE / SATA to USB adapter, make sure it has fittings on the end for both 2.5" and 3.5" EIDE drives. You plug either the ide end or the sata end to the adapter head and plug the usb cable into the host computer. The host then reads it as an external HDD
Nov 15, 2009 | Computers & Internet
Copmuter wont start
You can buy a external 2.5inch HDD enclosure which will allow you to remove your HDD from your current laptop put it in the enclosure and hook it up to another computer via usb allowing you to copy the files of the old HDD.
There are also multi purpose devices that allow your to hook up either IDE or SATA drives of 2.5" or 3.5" drives via USB an example of this device is at link. http://techgage.com/article/vantec_sataide_to_usb_adapter/
Mar 18, 2009 | Computers & Internet
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Toshiba (HDD2181) (hdd2181-50pk) 30 GB Hard Drive Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
