Question about NetGear RangeMax WPN824 Router
HELP i got a wpn824 netgear wireless router for my ps3. all the wires are pluged in correctly but when i take the connection test on my ps3 the ip address succeeds but the internet connection fails.does anyone know a solution
    President:
  • 1,214 Answers
I had to manually set access on my Wii even though it said everything was right.
If you can manually set it up, do that. You will need the IP numbers, which can be found by going to a command prompt, and typing ipconfig /all.
You will see 192.168.xxx.yyy and 255.255.255.0, and 192.168.zzz.uuu.
The first is the IP of the computer your on.
The second doesn't matter, but you'll enter the same on the PS3.
The third you'll duplicate in the PS3.
Setup any security you may have, and it should work. Let me know what you come up with. I have suggested this to others, but have not checked to see if this made their system work.
Posted on Jan 31, 2009
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
I had my Laptop worked and it was reset back to out of box
You need to RESET your wireless router. Her is how: Press and hold the Default Reset button until the test light blinks on (about 10 seconds). Release the Default Reset button and wait for the router to reboot. The default administrator's password is password The default IP is 192.168.1.1 Hope this helps
Jun 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
Internet connection fails on ps3
im really only experienced with xbox but your best bet is to call sony for help.
Jan 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Help with a netgear wpn824 v3 and configuring for my PS3 and PSP.
2 things you can try:-
1. make sure you enter the subnet mask and the gateway on the PSP or PS3
You can get these values on a connected computer
2. Try connecting to the Netgear and changing the channel if in UK try channel 4 or 7
Jan 12, 2009 | NetGear RangeMax WPN824 Wireless Router...
How to add a laptop to netgear wpn824 router
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Oct 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Reset
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax WPN824 Router Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
