Question about Kenmore 62602 Electric Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Dryer tumbles, but no heat.
Cleaned lint trap.   Opened lower panel and cleaned out lint.  Removed cover from fan and cleaned out (lots of) lint and muck.  Cleared fan blades,
Checked rest of exhaust system to outside, everything is clear.
Ran the dryer and checked voltage on the leads to the little white fuse attached to the blower assembly.  Nothing.  I'm assuming there would be voltage if it were still good.  Is this correct?
Thanks.
  • Kenmore Master
  • 8,220 Answers
Well your high limit is blown. It mounts up top of the heat element chamber.
Posted on Jan 31, 2009
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Whirlpool dryer heats and tumbles but doesn't dry
Sounds like it is still clogged up. Is the blower running?
Feb 23, 2014 | Whirlpool Dryers
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer heats,tumbles,but takes several cycles to dry a load(small).Not much air coming out of vent and have cleaned vent out.Any ideas?
The fan that pulls the hot air through the dryer and pushes the exhaust out through the vent hose is plugged with lint. You will want to remove the cover on the fan and manually clean the fan out. I had the same problem with my dryer, I was astounded by the amount of lint that was trapped in the fan.
Also look inside the cloths drum on the back wall and make certain the hole in that wall are not clogged with lint also. Use a flash light and make sure the hole are perfectly clean.
Good luck, clean it all out and let me know.
Regards,
Sep 09, 2009 | Maytag Dryers
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jul 22, 2009 | Fisher and Paykel DEGX2 Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
522 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
