Question about Maytag PAV3240A Top Load Washer
Fills with water and stops I do not hear timer clicking
Your help would be greatly appreciated. This has happened before. The tub fills and then stops. I believe it is a overload problem and the machine automatically turns off. I had it taken out and repaired beofre. They said it was a rtest button that needed to be reset - that's all. But $75 later... If you could tell me where the reset button is located I can do it myself and save on money and hassle. I have to miss work to be there for pick up and delivery. there is a re set portion of the load size on the front of machine -- but that is not the reset button the repairman talked about thank you in advance for your help
  • 331 Answers
Your repairman was pulling your leg. There is no "reset" switch on these. The lid switch is bad. You know how, when it is washing clothes, you can lift the lid and the machine shuts down? That's the lid switch doing that. Now, you lid switch is failed, so the machine thinks the lid is open. Replace the switch and all is well in the world. The part number is #12001187 and lists for ~$14.00. Can be purchased at your local appliance parts store.
Posted on Aug 01, 2007
  • Tracy Farrell
    Tracy Farrell Aug 05, 2007
    Please post back with your resolution.
Washer stopped draining
Something like a sock or small rag is stuck in Pump. That will have to be removed if possible or replace Pump.
Nov 14, 2017 | GE WJSR2070B Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Oh Mr. Guru,please help!
for the second problem wher the water runs and never reaches level, check to make sure the drain hose is higher than the water level. if you allow the drain hose to come out of the machine and lay right on the floor with out first coming up above the height of the tub, the water will run out as fast as it comes in. hope this helps, let me know
Apr 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwasher will not go thru wash cycles
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Too Much H2o
either your waterlevel switch is bad or the hose from the tub to the switch is leaking air. more info would do you have to turn the water off at the wall for the water to stop rising or do you just have to push the timer knob in?? let me know, i can definitely help to diagnose!!
Apr 24, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
Maytag PAV3240A Top Load Washer Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
