Question about Acer Aspire 5100 Notebook
Cant get router to work
I want to plug in my new linksys router to run another acer laptop i get to the electrial plug in it refuses to work oit shows not plugged into out let why
  • magha Jan 31, 2009
    IVE TRYED OTHER OUTLETS IT DOES NOT WORK WHEN PLUGGED IN THE PITCURE SHOW PLUG NOT PLUGGED IN
  • Report
    Report May 11, 2010
    it's brand new? does the outlet work? can you try another outlet? is the power connection from the plug to the router snug? is there a light switch to the outlet you're using that accidentally turned it off?
We have wireless network at office. My laptop at times go in at times refuses saying not found certificate to log me. Its acer aspire 5315 running windows xp service pack 2 wesmosis, though it came w
I would check the settings of the router at work. It will show the"allowed devices" and may have allowed you on a couple of times as a guest.
Mar 12, 2013 | Computers & Internet
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Jan 25, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I cant get a conection to my lap top, even when it is sittingon the desk beside the desk top and connected to the router linksys.
try turning off all 3 for 60 seconds, then powering back up modem...router...pc.
If that doesn't work, try running the network connection wizard
good luck
Oct 15, 2010 | Acer Aspire One PC Notebook
I HAVE AN ACER LAPTOP WORKING OFF A LINKSYS ROUTER AND NOW WOULD LIKE TO ADD MY NEW TOSHIBA LAPTOP. HOW DO I DO THIS, KEEPING IN MIND THAT MY TOSHIBA IS NOT CONNECTED TO THE INTERNET
Make sure that the wireless is turned on, on the laptop. Then go to network settings and veiw wireless networks, or if your running xp double click on the wireless signal on the bottom right corner. Click on your wireless sigal and hit connect and that should be it.
Apr 13, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect to wireless network
To connect to the linksy's router you will need to run the linksy's setup disc on each pc in that netwrok.
Mar 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Acer 4420 Notebook does not see Linksys router
Try hard reset of the router and reconfigure it
Jul 29, 2008 | Acer Computers & Internet
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Bought a new acer aspire 3680 have linksys wireless router it detects it i put my pass in and i
Do you mean password?
Your post is difficult to understand because of the lack of punctuations and capital letters.
Remember, all we know is what you post, so try to be more legible.
Try resetting your router to defaults.
Nov 20, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
