Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore elite coldspot 106.55606400 --fridge not cold enough --
If the suggested temp of the fridge is 37, is colder 36 or 38 --do not have manual --thank you
  • 410 Answers
37 is the atual temperature that your trying to acheive. so to make it colder you would go down to 36 which is one degree cooler. hope that helps. thx peyton
Posted on Jan 31, 2009
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
After power interruption we find the temp is sitting at 48 degrees fridge side and 19 degrees on the freezer side.
After about 24 hours your temps should be close to zero in freezer and about 37 in refrigerator. If not check position of thermostat control and turn clockwise for colder temps if necessary.
Mar 16, 2016 | GE PSC23SGRSS Side by Side Refrigerator
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
I have a lemair RS250S fridge only have had it for awhile lost manual need to know which way to turn dial to turn it colder.Please
Hi, From what I can see from my manual, 6 is the coldest temp and 0 is off. We have just had ours on 4.5 and the diet drinks have exploded. So I suggest that you keep it under 4.
HTH
Dec 30, 2010 | Refrigerators
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Oct 05, 2006 | Candy CPCA250K Bottom Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
840 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
