Question about Proscan PS35660 TV
Looks like projection picture has shrunk in size and wors overlap each other
Long>distance>layout>for>your>profile
Posted on Jan 31, 2009
Screen has shrunk and picture is now tripled
The projecction width has reduced with the three guns going out of alignment to give the three images.
It is possible that the power supply voltage has reduced which has made the projection drop down to give this reduced size.
Check for possible failrue of the filter capacitor or the fault in the SM pre driver circuit, possible redduction of value of some associated electrolytes.
Check for visible signs of capacitor leaks or use a multimetter to confirm.
Aug 22, 2010 | RCA R52WH73 Projection Television
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
My picture size shrunk
you have a bad cap in the vertical section depending on your skills as an electronic tech see repairman
May 19, 2010 | Funai F42PDME 42 in. Plasma Television
Out of focus. The picture overlaps itself.
if you mean the picture looks like a 3-d movie without the special glasses and you want to repair this yourself contact ,me at techman32katyahoodotcom
Aug 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Picture is messed up
need to replace convergence control chips
Jun 12, 2009 | Televison & Video
Have picture but color overlaps and is not sharp or crisp.
depending onwhat board you replace you may have to copy the light engine data to the chassis to sync the color wheel.
Dec 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Shrunk picture?????
enter the service menu mode and adjust the v.line adjustments
Aug 27, 2008 | Sampo SME-34WHD5 34" TV
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Zenith IQB60M92W 60in Rear Projection
Sounds like some kind of local interference. The first thing I'd try is disconnect the antenna input. If the wavy line goes away, it's probably something coming in through the antenna. Then I would start shutting off the circuit breakers until I was down to just the one the set is plugged into. If it goes away I would start flipping the breakers on, one by one until the noise returned. If you can isolate it to one circuit, start looking at everything that is on that circuit. If all else fails, call a TV tech.
Oct 01, 2005 | Zenith IQB60M92W 60" Rear Projection...
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
