Question about Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs
Grass hog B&D cst2000. spool drops and won't spin. How can I take it apart?
richroth
  • 9472 Answers
SOURCE: My grass hog 12" cst2000
Here is a link to the manual.
Posted on Sep 13, 2011
I have a cst1000 cordless trimmer. The recharging unit has failed. Do you sell a replacement that has the red and green lights indicating charging or charged?
Try this:
http://cgi.ebay.com/NEW-B-D-12V-VOLT-CST1000-Cordless-Grass-Trimmer-Charger-/200504468177?pt=LH_DefaultDomain_0&hash=item2eaeff62d1
If this has been helpful, please leave positive feedback. Thanks!
May 02, 2011 | Black & Decker Cst2000 12 - Volt Cordless...
It does not turn on even if it was charged for 24 hrs
When it charges, does the red light come on on the charger? Some of the CST2000 chargers make bad connections, and they don't actually charge.
Make sure the red light is coming on when you're charging the battery. If the light is coming on and you still can't use the trimmer after charging, you'll need either a new battery or a whole new battery pack (the black handle of the trimmer).
Hope that helps!
Sep 04, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How long does the trimmer last on a charge?
how long is a peice of string!!!!! how oftern do you use it as the charge will always die what ever
Jul 16, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Have a cst2000 but do not have the charger
The charger for the CST2000 is part #243248-00, but it is obsolete now. You could maybe find a used one for sale on eBay or craigslist, though.
Apr 17, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
I don't need a manual - I need a replacement handle
if your refering to the batt handle then its a obsolete item with no replacement part number. your part # is 243215-00 and your best bet is to sell it or put lots of ducktape or epoxy or keep checking ebay
Jul 09, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Weed whacker
I was unable to get that ring off also... I was able to pull plastic side apart far enough to pull motor out and "rewire" it. Even fit back in when I was done... just barely. and was very gentle...
I do not know how to get the ring apart, though.
Feb 01, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
254 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
