Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
30 amp fuse blows when trying to start engine
I have checked for shorts and can not find any. I put a new 30 amp fuse in and after several rotations on the engine the fuse blows. Could the armature be causing this?
  • joe May 11, 2010
    does the fuse blow if the ignition is turned on, but the starter not cranked?
  • 24 Answers
I always start by unplugging lights, kill wire to coil electric clutch if it has one ,sometime its the fuel shut off solenoid on the bottom of carb if it has one.
You can keep trying until you find the thing that does not blow a fuse or use an ohm meter to read from pos cable to ground of tractor unhook ground wire to battery you will read short to ground thru coil kill wire,starter solenoid small wire on spade,fuel shut off
solenoid ,electric clutch ,rectifier (charging system )and large wire to starter thats why I unplug them .
I have seen more shorts from lights , fuel shut off solenoid , charging system. not ing coil not safety switches not even bad starters.
good luck
Posted on Feb 06, 2009
I HAVE A 1997 GMC YUKON, 5.7 ENGINE. RECENTLY WHILE DRIVEN THE ENGINE JUST SHUT DOWN. THE ECM-1 FUSE WAS BLOWN. AFTER REPLACING THE VEHICLE STARTED BACK UP, WENT MAYBE A 100 YARDS AND IT BLEW AGAIN. I PUT...
Sounds like the computer has short in it. You can get a computer at Oreillys auto parts for around $140.00. You will need to call the part store and order the ecm and give them some info on your engine, so the replacement ecm can be programmed for your vehicle.
Jan 03, 2011 | 1997 Chevrolet Tahoe
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have Exmark 52 LazerZ with Kohler ch25 engine. Engine stalled in heavy grass. Tried to re-start; engine turned over several times at lower RPM but stalled almost immediatly (PTO switch disengaged &...
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Jul 16, 2009 | Ford Tractor 8n Front Emblem
No start, blown ignition fuse 30 amp.
If it is the AM2 (30A) fuse that is blowing, check the ignition condenser, capacitor, within the ignition assembly. I just removed it and assembled the ignition back together. I am in the process of ordering a new one from Rock Auto for a total of $2.57. It seems to be a common issue. The condenser is actually a capacitor and the issue is that they internally short.
Jun 17, 2009 | 1993 Toyota Corolla
30 amp ignition fuse in engine compartment blows at start
It sounds like a bad ignition switch or something is grounding out.Try to isolate the problem to key positions.See if the fuse blows when you turn the key to ACC(when your dash lights come on without starting)If the fuse does not blow then when you go to start it and it blows it could be one of many problems,the more common ones could be ignition switch,wiring,starter relay,starter soleniod,or perhaps the starter itself is shorting out,this can sometimes happen when a starter goes bad.
Apr 12, 2009 | 1996 Hyundai Accent
30AMP FUSE KEEPS BLOWING WHEN I CONNECT THE BATTERY
Check the positive battery cable for abrasions all the way to the starter and also to the alternator. Your battery could have a short between one of the cells.
Apr 18, 2017 | 1996 kawasaki VN 1500 Vulcan Classic
No spark when trying to start the engine on 98 chevy blazer
Check for dead battery. Test wipers, radio, headlights and heater fan. If all work normally, battery is probably charged and you may have bad starter or alternator ....
Good luck...
Nov 11, 2008 | 1998 Chevrolet Blazer
Blowing 30 amp engine control fuse.
You say it eventually allows you to put new fuse in, do you mean when it sits for a while, a new fuse won't blow, but if it blows and you immediately replace it, it blows again instantly?
Sep 05, 2008 | 1997 Dodge Ram 1500 Club Cab
30 amp fuse/ in box under hood
The 30 amp fuse is most likely for your starter. Check that the red thick wire (could be black as well) leading to the starter and starter solenoid is properly attached and is not touching anything that would short it out and therefore blow the 30 amp fuse. The short may even be inside the starter in which case it will need to be replaced or repaired. Hope this helps.
Alex
Jul 09, 2008 | 1996 Jeep Cherokee Sport
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
447 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
