Question about Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-1910LS will not eject drawer
Installed new Pioneer DVR-1910LS DVD burner in my XP system. At first, everything seemed to work OK. Next day, light comes on, but drawer will not eject either manually or through XP. Two questions: Does anyone know the problem/solution? How do you contact Pioneer cust. serv?
  • glueguy Jan 31, 2009
    I, "glueguy", solved my own problem. One DVD burner's jumper was set for "cable select" and the Pioneer was set for "primary". Both were on the same cable.
  • 4 Answers
The drive mechanism might have failed try to contact pioneer people !
OR if it is NOT in any WARRANTY then try to open the drive up !!!!!
Posted on Feb 03, 2009
AFTER I REINSTALL WINDOW XP MY PIONEER DVR 112D STOPE WORKING IT SID INSTALL CAMPATIBLE DVD DECODER
Try running a firmware update. You can get the firmware at the following link: http://www.pioneer.eu/eur/support/software/DVR-112DSV/index.html#download_103
If you have not ran your windows updates yet you might try to do that. Alot of issues like these were fixed with service pack 2 for windows XP. Hope this able to help you.
Apr 14, 2011 | Pioneer DVR-112DSV DVD+RW Burner
My pioneer cd/dvd burner model DVR-110D will not write to cds it will readand write to dvds, it will also read cds but not write to cds. how can I get this fixed, my OS is WINXP PRO?
Welcome to Fixya.
Seems like you're having a software issue that prevents your system to read/run a disc when inside the operating system. I have included the official fix from Microsoft:
DVD Drive Troubleshooting
All you have to do is to click on "Run Now" and follow the on screen prompts - just remember to eject any CD that you may have inside the drive.
Please note that if this does not work, then the drive needs to be replaced. You may contact Pioneer for replacement options in case that happens.
Hope this helps and Thanks for using FixYa.
Apr 07, 2011 | Pioneer DVR-110D (0012562773964) Burner
I have data to save to a disc on windows xp to the Pioneer DVR. Every disc I place in the drive seems to be full; no capacity or space available.
The burner is defective: the laser sensor is not working correctly. It cannot be fixed, you will need to replace the burner.
Dec 09, 2010 | Pioneer DVR 108 Dual format 16X DVDRW...
SOLUTION: For Windows XP and Pioneer DVR-K16 DVD Drives
Dial +1-800-204-4427 and Get end of support information for Windows XP and find out what you need to know to upgrade to Windows 10 or find a new PC.
Apr 14, 2017 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Pioneer DVR-1910LS not even recognizing DVD-R DL disks
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 09, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Is it compatable with my desktop pc?
Ok. Well basically CD, DVD and Hard Drives are all cross compatible platforms so you don't have to worry about compatibility issues. If your asking me to choose I would say that you remove the CD writer instead. But before you do this make sure you have enough extra sockets in your motherbaord to plug in your Pioneer DVR-1910LS 20x DVD±RW IDE Drive w/LightScribe if your CD Writer uses IDE interface your inluck coz you can use it in place of the Pioneer DVR-1910LS 20x DVD±RW IDE Drive w/LightScribe, but if it isn't make sure you have a spare IDE socket in your motherboard. Simply remove the side panel use a flashlight and see if there are vacant IDE sockets, it's usually long in black, white or blue color. see the picture below.
If its vacant follow the steps on the link below simply copy and paste the link on you browsers address bar.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&dlc=en&cc=us&lang=en&product=390426
I hope this helps you...
Jan 22, 2009 | Compaq Presario S6300NX PC Desktop
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
Oct 12, 2008 | Pioneer DVR-213LS DVD±R Dual Layer Burner
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Pioneer DVR-107D DVD±RW Burner Logo
189 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
