Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Tryin to bypass electronic timer on inglis oven
  • s_ls Feb 01, 2009
    Thanks a bunch,figured as much...just pushed it back in....so will tackle this in the am.!!!
    Problem Solver:
  • 10 Answers
You have to find the main live going into the timer, and the live from the timer to the oven switch, and firmly, and safely connect then together..
Posted on Feb 01, 2009
Is it an expensive job to replace the oven timer on my cooker?
I can do job for a lot less money or yes you can bypass timer, No Problem. David "The Famous Forry"
Oct 19, 2017 | Ovens
Morning I have a Stoves EFA600H electric oven and whilst the hob still works ok the clock and oven do not. The clock did start flashing last week and now has gone completely - any...
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Feb 23, 2011 | Stoves Ovens
Kitchenaid superba electric oven (includes convection feature) and the entire digital panel suddenly stopped working after 6 years of perfect service. The stove top burners (acrylic top) appear to be...
It sounds as if the electronic clock/timer has failed and needs replacing. If you don't use the timer and don't need the clock it can be bypassed so that the oven will still work. A repair person should be able to do this fairly easily.
Feb 13, 2011 | KitchenAid Ovens
My oven wont heat up after i reset it
When you refer to resetting it are you talking about turning the mains power off and then back on?
Or are you talking about resetting the electronic timer? The electronic timer must be in the manual mode for the oven to work. Turn the oven on and play with the timer. When the oven indicator light comes on you know the oven is working.
Feb 13, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
My oven wont come on and i know there is a problem with the electronic programmer, can i reset it or not use it at all
If you cannot reset the oven timer, then it will not heat the oven.
This being the case, then it is possible in some cases to bypass the timer, or the alternative is to to replace the timer.
Jan 25, 2011 | Zanussi ZBF360 Electric Single Oven
SARENA SK400X BOTTOM OVEN WONT WORK BEACAUSE LED TIMER HAS BURNT
Look for the relay on the timer and the 2 wires that goto it.
Basically short the 2 wires that goto the relay and job done.
If there are more than 2 wires be careful as you may blow a fuse if it's connected incorrectly.
Jun 18, 2009 | GE Built-In 24" Double Electric Wall Oven
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
1,155 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
