Question about Danby DWC513BLS Wine Cooler
Danby wine cooler
Can't seem to get temp reset to low enough. seems to be running but i can't reset temp
  • Anonymous Jul 02, 2008
    I have a wine cooler model DWC513BLS I have an E4 code on the left LED , the RUN light does not come on and the temperature is 79 degrees and wont come down, can you tell me if there is anywhere one can find a troubleshooting section on DANBY products (it's not on their site) do I need to change the compressor altogether or is it someting else...thanks for your help...
    Richard
  • 20 Answers
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
SOURCE:
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
Danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Aug 21, 2009 | Danby DWC283BLS Wine Cooler
I have a danby wine cooler that is running hot. I am outside of the reg. warranty but if this is a compressor issue it is covered. How can I tell what is going on?
if the motor are running the gas level are too low . if the motor are not running check the thermostat. if there are power by the motor and stil not running then it is the motor
May 13, 2009 | Danby DWC283BLS Wine Cooler
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Danbysilhoutte
sounds like you need to replace the control board, i believe there may be two parts here - if there are, try replacing the power control board before trying the electronic control piece... this is the board that has the low and high voltage circuits and relays.
May 18, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC513BLS Wine Cooler Logo
422 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
