Question about Linksys Wireless-G Broadband Router
Connecting wireless router to my laptop
I bought a new compaq laptop with wireless connectivity and a linksys wireless-g router. How do I get the laptop to recognize the wireless router?
  • vondraco Feb 01, 2009
    can not get on internet exp
    Problem Solver:
  • 5 Answers
You have to open up the wireless menu on the laptop and have connect to the linksys, which will be your router and it will ask for a code and that code is on the back of the router and you will connect as soon as you put that code on there
Posted on Jan 31, 2009
It just stopped sending a signal and 5 hours later it started working then stopped when i tryed to lock it and now it wont work again all lights are on i reset it powered it back on prested the reset and...
The only computer I have is a Dell Insprion E1505 laptop and it is connected to a "COMCAST" cable modem. Windows XP, not Vista is installed. I purchased a LINKSYS WRT54G wireless router. I installed the setup disk and connected the modem to the router, and the router to the computer as step one, but when step two had me disconnect the router from the laptop so it could connect via wireless network, it just says "easylink advisor could not establish a wireless connection with the router
two laptops, a desktop PC and my son has Xbox live. I recently bought the Linksys wireless-g router with speed boost and that didn't work. If any of the laptops were on, the other wouldn't work and my son's Xbox live would lag. I was thinking about exchanging it for the Linsys wireless-N broadband router but then I read the reviews and they were horrible. I need something of that sort but something that isn't known for being unreliable and dying.
I bought the Turtle Beach X41 Headset, and it is causing some problems with my wireless connection. Due to a number of reasons, it is not possible to directly hook up my 360 to my modem. So, if I bought a new router that can operate on a 802.11a frequency, would that help or not? My current router is a Linksys Wireless G, 2.4GHz, router. Microsoft has said that an 802.11a frequency router could fix problems with other wireless electronics. If it would help, which router should I buy? I've read a few reviews for the Linksys WGA54AG 802.11a, and everyone says it doesn't work good. Any suggestions on another brand
i tink with these you can do some thing
Dec 19, 2010 | Linksys Wireless-G WRT54G Router
Tip
Wireless Network Reset and Setup - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Next
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_field_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
  • Click on Wireless Security
  • Find the Security Mode field
  • Choose WPA2 - Personal
  • WPA Algorithm choose AES
  • WPA Shared Key type in your new password you will use to connect to your network
Click Save Changes and your router will now reboot. You will now need to enter in that same password (WPA Shared Key) when you first connect with your laptop to your wireless network
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
I bought Linksys El000 How do I connect to X Box?
You will need to check the wireless settings of the router. You will needthe name of your wireless network ( SSID) and the wireless network key or passphrase.
You are using E1000 router. This is new series of routers from Linksys.
If you are using the security type WPA/WPA2 mixed then use only the WPA personal and TKIP.
now go to X-box and try to connect to the wireless.
Click here for more information about how to connect to the wireless on X-box
May 17, 2010 | Linksys Wireless-N WRT150N Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
I bought new laptop Dell vostro, it is not able to
Probably your network is secured so you will need to configure connection (provide WEP or WPA passkey to connect).
Double click on wireless network name you wish to connect and put encryption key
Nov 26, 2009 | Linksys Wireless-G Broadband Router
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
Loss of Connectivity
Libog1 - did you install any additional wireless software to connect to the router (Linksys software) or are you just allowing Vista to connect directly using Windows' built-in wireless management?
Ben
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G Broadband Router Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
