Question about Kenmore 24032\24036 Top Load Washer
I have a small Kenmore top loading washer that quits radomly just before the rinse cycle. I have to manually pull the knob and move it a little forward and press it in, then the washer starts and completes the cycle. What is the problem? Tara Jollie Anchorage, Alaska
  • 640 Answers
Sounds like a defective timer,,,but test it first,,when it stops before rinse ..open and shut it firmly we are testing lid switch,,one of them is defective,,keep me posted onthejop
Posted on Jan 31, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore top load washer 110
hi thanks for the question i would check the lid switch very common for that make thanks the appliance doc
Sep 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
