Slimtype Combo LSC-24082K issue
I have been given many solutions but nothing has worked. I am re-posting per your suggestion Ekse. Please help!
  • 1 more comment
  • rhdestiny Jan 31, 2009
    Sounds good. Just email me when you are ready.
    THANK YOU!
  • rhdestiny Feb 04, 2009
    He offered to help but when we actually got together to solve it, I realized that he had not even read my entire problem. I had taken the time to explain the entire situation but he didn't read it. Because of that, we spent the entire time going over what I had already tried (and had not worked). It was frustrating.
  • Ekse May 11, 2010
    I'll be able to help you over remote support in about a hour. I just got another customer and have to help him first.
  • 13,433 Answers
Ok, I'm finaly done. If you open www.fastsupport.com
enter any name, and the session key for our session is
315 929 620 I'll be waiting, it will work for around a hour before it expires.
You can also click on this link below
http://www.fastsupport.com/315929620
Posted on Jan 31, 2009
  • 1 more comment
  • Ekse Feb 01, 2009
    seems like I lost you... the above link should work in reconnecting... went to the toilet and came back seems you had frozen.
    I'm still here.
  • Ekse Feb 04, 2009
    its too bad you disappeared. the drive seems faulty.
  • Ekse Feb 04, 2009
    We spend most of that 10 minutes looking and testing, and it was clear the drive is unable to read CD's but works with dVDS thats a clearly faulty drive, I have those over here. noting helps on that, maybe the replacement of the lens or internal electronics. oh I've done it all on them. use your warranty or buy a replacement drive for it.
Failure to boot Acer Travelmate 243xc Ms2138
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Mar 08, 2013 | Acer 20 Travelmate 240 243xc Ms2138...
My acer travelmate 240 wont read cd's anymore. been in device manager and on dvd/cd-rom drives it has a ! slimtype COMBO LSC - 24082K
It is a pretty common fault when drive can not read one type - cds or dvds. That means you have to replace the drive. Price of the drive is not that high so that makes no sense to try to fix it. Cheapest I guess would be eBay (from what I see right now 20 dollars including delivery) but also there are plenty of on-line stores. Just use your favorite search engine to find the drive or simply go to the closest computer repair place and tell them that you want the drive replaced.
Sep 06, 2009 | Acer TravelMate 2300 Notebook
Slimtype DVD ROM unable to read self made DVDs ONLY...
I found this problem to more users of this model ..the only thing I can advice you is to try to change with another comp model ....some have a lot of theories ..about it ...and long fixes..but It seems that the problems came with some vista updates ...so ..either get on xp sp3...cause its reliable ..or change it ..cause it will never work proper..
Apr 08, 2009 | HP Pavilion dv6345us Notebook PC
Firmware Here http://support.gateway.com/support/drivers/getFile.asp?id=19715&dscr=Firmware%20Flash%20Update%20PGS3%20for%20Lite-On%2048x%2024x%2048x%20Recordable/Rewritable%20CD-RW%20Drive&uid=222228034&site=emachines
After you have downloaded the firmware update above,the Firmware flash utility,and the FlashFix and saved them all to the desk top.Run the firmware flash utility in step 1.(and follow the directions) (after you run it and make your back up,move on to step 2), Run flashfix in step 2 (and follow the directions)After you have completed steps 1 and 2 move onto the flash,(just click on the update firware file on you desktop and run it.(follow the directions n the screen)
Note: Firmware flash utility =LtnFw (use it for the backUp)
Step 1: Make a backup copy of your current firmware. You can do so using LtnFW. you should make this backup incase you decide that you want to undo the firmware flash, you will need a backed up firmware.
Note: FlashFix=flash fix
Step 2:The firmware flasher is checking your drive and seeingthat you have an OEM model and is thus refusing to flash it. FlashFix will patch the firmware flasher so that it will agree to flash your drive.
Note: Flash=The firmware file you downloaded
Step 3: After using FlashFix, run the flasher, make sure that you select the correct drive from the drop-down list, and flash
I hope this better explains the steps
Jan 31, 2009 | Computers & Internet
Slimtype Combo LSC-24082K does not recognize audio/program software
  1. Click Start, click Run, type regedit in the Open box, and then press ENTER.
  2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
  3. To enable automatically running CD-ROMs, change the Autorun value to 1.To disable automatically running CD-ROMs, change the Autorun value to 0 (zero).
  4. Restart your computer
Dec 31, 2008 | Computers & Internet
Removing combo lsc-24082k from an acer aspire 1355lc
And the problem is? If U don't know how to remove, how are U going to install?
May 27, 2008 | Acer Computers & Internet
Problem.
Hi Ekse,
Thanks for bringing this to my attention. Could you please email me at alex@fixya.com so that we can further discuss it.
Thanks
Alex
Mar 17, 2008 | Acer TravelMate 2300 Notebook
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
