Question about Acer AL1715 17" LCD Monitor
Acer al1715 main board is a problem
I bought three al1715 monitors and the problem was always the board that plugs into the motherboard,,,,,,,it could also be something on the power board that gives out too much power to something on the video board,,,,,,all i want to do now is to find somewhere to buy that board that hooks up to my motherboard[my powerboard is fine]
I JUST TO KNOW WHERE TO GET-BUY-FIND THAT VIDEO BOARD
  • 558 Answers
Shop jimmy on E bay send him an email question
Posted on Mar 22, 2009
  • 78 Answers
Please look here..and vote me if its works..
http://images.google.nl/imgres?imgurl=http://mperlitsch.hintergrundbild.com/hp/HP1702_klein.jpg&imgrefurl=http://mperlitsch.hintergrundbild.com/hp1702.htm&usg=__Iw4raAzsQ1z20fR0DP2JRRwJYCw=&h=306&w=300&sz=27&hl=nl&start=3&um=1&tbnid=pVFWk-IRYjVy5M:&tbnh=117&tbnw=115&prev=/images%3Fq%3Dhp%2B1702%2Bmanuel%26hl%3Dnl%26lr%3Dlang_nl%26sa%3DN%26um%3D1
Posted on Jun 20, 2009
Cant close the Menu Box from the Monitor
More like to be bad Flash ROM in the logic board is scrambled (not much you can do unless the firmware can be reloaded). You can try looking inside for such thing as bad caps on the logic board and the power supply/inverter board just for luck.
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Acer AL1715 17" LCD Monitor
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor resolution problem
set your dispaly resoluiton to 1024*768
Mar 24, 2009 | Acer AL1715 17" LCD Monitor
Any body can tell me the acer sevicing center in vishakhapatnam
Bad capacitors on the internal power board capacitor replacement is indicated
Feb 02, 2009 | Acer AL1715 17" LCD Monitor
AL1715 Acer flashes twice when starting up but does not go on
blown capacitors most likely cause, replacement of the blow caps on the main power board is advised
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job.
e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
Oct 30, 2008 | Acer AL1715 17" LCD Monitor
I have a ACER LCD Monitor that will not power up when turned on. The power light does not come on. (AL1715)It was purchased under three years ago.
Check to see if the computer is turned on and that the monitor is plugged in. If all Ok, then your monitor is burned out. Do not open the monitor case and look inside because you can get a shock. Just replace it. Three years is about normal life span.
rmatheson@wowway.com
Oct 01, 2008 | Computers & Internet
MY ACER aL1715 MONITOR IS ALL WAVY AND IT LAGS OR SLOW TO RESPOND.
If you are electronically minded, then check the capacitors on the power supply board for any signs of buldging etc and replace as needed.
If not, send it down to your local TV tech and get them to do it.
Jan 19, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 20, 2007 | Acer AL1715s (Silver) 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
213 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
