Question about Maytag LAT3600A Top Load Washer
Will not spin
Maytag top load washer lat 9824 wash ok will not spin lid switch ok
  • 117 Answers
If the motor is not running, it could be a faulty timer. If the motor runs, it could be the transmission. Check to make sure the pump belt is ok and the pump pulley is not seized by tilting the machine back and checking.
Posted on Feb 26, 2009
My Maytag top loading washer Won't Spin
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.Here is the part you need.
Jan 06, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
The washer is not spinning.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.Replace the "lid switch" with this part.
Jan 02, 2011 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer
TAKE A LOOK AT YOUR LID SWITCH MAKE SURE PLASTIC PLUNGER IS MAKING CONTACT,, SHOULD MAKE CLICKING NOISE WHEN OPEN AND CLOSE LID
Nov 29, 2008 | Maytag Performa PAV2200
Maytag Washer won't switch from rinse to spin
You have a bad lid switch. Before I retired Maytag had a lid switch kit that improved the switch that was originally in it. The problem would usually present itself if a person accidentally dropped the lid with a bang which would put the lid switch out of adjustment.
Jan 08, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Maytag LAT3600A Top Load Washer Logo
221 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
