Question about Kohler 12 kW Emergency Power System - 12RES-L
Need info on installing circuit breakers for Kohler RES12 transfer switch.
  • Eric Wissenbach
    Eric Wissenbach May 11, 2010
    What exactly do you need to know about it?
    Problem Solver:
  • 5 Answers
Gotta be more specific! What kind of info do you need?
Posted on Sep 04, 2009
What size breaker goes into the unit
it depends on what you are talking about,if you need a circuit breaker in the transfer switch,then you cant go over what the amperage of the generator is,if you need circuit breakers for the outlets on the generator,that also varies depending on your generator,if you would of given all the info that we need,i wouldnt have to give you this kind of answer,it couldve been more concise,make,model,s/n of generator,s/n of transfer switch etc.
Apr 16, 2015 | Electrical Supplies
Do I need a main breaker in front of a manual transfer switch
I'll assume you are isolating the main breaker that carries in current from the pole (this is called a service disconnecting means). By the term "main breaker" I'm assuming you are referring to a feeder disconnect; that is to protect the generator from over-current.
Under these assumptions, no, the generator has a circuit breaker capable of interrupting the circuit leading to the transfer switch. Under these conditions, you could view the genset's breaker as a "main".
Sep 23, 2014 | Electrical Supplies
To be code compliant, I'm sure you do. The transfer switch transfers between 2 power sources, usually the electric utility and a generator. Both sources connect to the transfer switch and you select which one provides power to each circuit. The main breaker provides circuit protection to the internal wiring regardless of where the power is coming from. Even if the transfer switch has circuit breakers, there should be a main breaker which can cut off all power to a circuit, or one circuit in an emergency. In addition, unless all your circuits are on the transfer switch, the main breaker is absolutely necessary.
Sep 23, 2014 | Washing Machines
Is there an internal fuse to the starting switch of an older model kohler generator for an r.v.?
Which model???? generally there is a control circuit fuse yes on most models
Oct 24, 2012 | Kohler Electrical Supplies
My res12 indicates HE high engine temperature it is brand new 147 hours runs. best regards
new engines will run hotter then broke in ones do to tolerances are tighter more friction if it continues contact your warranty service dept before your warranty runs out
Jul 28, 2010 | Kohler 18RESL 18 kW Emergency Power...
My Kohler 11RMY (40 amp) standby generator will not start
You should have two wire remote Start/Stop. It may need to be shortened in order to start.
Jun 06, 2010 | Kohler 12 kW Emergency Power System -...
Need circuit diagram for Kohler ATS part # K163341-800
Do you know the part number on the board. Kohler used numbers written with permanent marker on their controls boards. They usually started with a letter like A or B.
You might have a * 297373 or *297375. They usually had a big orange relay that stuck up in the middle.
The filter capacitors would always dry out over time and relays wouldn't energize correctly.
Depending on the board we might have a drawing.
We fix some of the older style. Check out our website: www. You'll find contact info. For fast response call in and be prepared with any board numbers you might have found!
Sep 02, 2009 | APC Automatic Transfer Switch (AP7701)...
Kohler 12 kW Emergency Power System - 12RES-L Logo
94 people viewed this question
Top Kohler Electrical Supplies Experts
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
