Question about Recoton Advent Advent 900 MHz Wireless Outdoor Speakers, AW810 Set of Two Computer Speakers
I just had my computer wiped out and put back on windows xp and now my speakers will not work I know it is a driver but I don't know how to fix the problem
You'll have to reinstall the driver for your peripherals. The sound card driver controls the actual speaker output. Do you have the full set of disks from when you got the computer? You could also look in your device manager for the sound card/speaker information it should give you a listing that has a yellow ? by it indicating there is no valid driver..
Hope that helps.
miranda
Posted on Jan 31, 2009
SOURCE:
Failed install with XP I had a bad key, bought windows 7 (downloaded) but my computer tries to run XP and I don't know how to wipe it out and install windows 7
I hope that you stored the download on something else. If you wipe that drive it will erase the download. Anyway you need to get a boot disk to load first and then try the install. Hirons boot disk. Look here: http://www.hirensbootcd.org/download/ dont click on the advertising.
Mar 24, 2013 | Computers & Internet
I want to take my computer apart but not sure what drivers i'll need once i wipe it clean and put it back together. i tryed once but know my front usb ports don't work
You would use the driver's from the computer's manufacturer's website for your make and model.
Get onlineand got to www.google.com In the google search box type: "MSISupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Jun 02, 2012 | Intel Motherboard
Dear Sir/Mdm, I just reformatted my computer and since then, I have no been able to get my speakers (altec lansing v1520) to work. May i please know what driver(s) I need to download to get it to work....
You don't need any drivers to make the speakers work what you need is the audio chip drivers for your motherboard ( the model of which you have not mentioned ).At the bottom right hand side of your desktop next to the clock do you see a icon of a speaker ?. If you don't , your sound driver has not been loaded. If you have the motherboard utility disc the drivers will be on it. If you don't ,you can go to the motherboard website on the net and type the model number and download all the drivers necessary to run the PC.
Just remember after loading the drivers remember to restart the PC to make the application run.
Jun 22, 2011 | Altec Lansing VS1520 2 Speakers
I have a Logitech Z-5500 Digital, and I push him to another computer, but I don`t have a manual or a cd, so I don`t know how to make work the sistem... please can you give me a solution ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
May 20, 2011 | Logitech Z-5500 Computer Speakers
Hi, recently wiped whole computer and reintstalled windows xp, how to fix multimedia controller for advent t9403. dont know how to fix this problem. i cant find the driver for this anywhere. also windows...
Make sure you have downloaded all of windows updates, for windows xp. You should be able to do search for advent website on a serach engine for your driver.
Nov 18, 2009 | Microsoft Windows XP Professional
Can't get speakers to work.
Hi...
Mostly of the sound driver now are need a compatibility if your installed driver is not compatible it will affect the hardware. It's better that you will know the model of your motherboard, if you know the model you need to search the model and download the sound driver witch is compatible.
For now the all motherboard are High Definition Audio.
ICmanServer
Jul 30, 2009 | Ozaki DT-500 3-Piece Speaker System...
Speakers are not being recognised
i would like to know if your on board soud or sound card is not being recognized by your system? as far as i know speaker will not work if your sound device driver is not installed. so maybe theres nothing wrong with your speakers. try to go to my computer properties go to system device hardware and see if there is an yellow exclamation in your sound device. if there is, update the driver using the provided cd from your motherboard, if its on board sound device. but if its a sound card, update the driver using the cd provided from your sound card. but if your sound device is ok and there no yellow exclamation, probably you hooked your speaker connector to the wrong jack. it should be the color green one. try and good luck
Jan 20, 2007 | Generic Memory 2-Piece Amplified...
140 people viewed this question
Top Recoton Advent Audio Players & Recorders Experts
Ron Rak
Ron Rak
steve-o steve-o
Level 1 Expert
Dayton Computer
Dayton Computer
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
