Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Light on, nobody home ??!!
Just moved in to a new to me house. The opener was unplugged when i got to it. When I plug it in, the light comes on, but nothing else happens. Anyone have any ideas ?
  • Anonymous Feb 12, 2009
    I also have a problem with my opener light coming on but the door not raising when I push the button on the wall. The opener doesn't make a sound when I push the button except for a light click. Also, the remote doesn't make the light come on, but it does make the little light on the back flash 5 times. My sensor eyes are green on the inside right, and yellow on the inside left. I think this all started right after a big storm. I have a 2003 Chaimberlain Liftmaster 1/3 horse lifter.
  • marty metzger May 11, 2010
    so far, it is doing exactly what it should. you plug it in and light comes on for 4 minutes. What else did you try. Is wall button lit. Did you push it. What about remote controls. Do they work. Did you code them? Give us something to work with.
The light flashing on the back of the operator 5 times indicates that there is an RPM sensor failure. They can be changed easy enough, but remember to unplug the operator first. The part # is 41C4398A. Your best bet would be to call a garage door company and get them to look at it. Your logic board may also be fried from the storm. Hope this helps.
Posted on Feb 12, 2009
Moved refridgerator to new house plugged it in will not come on lights or nothing. New had only 1 month. What would cause this?
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Apr 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerator was unplugged for a week. We moved it from one house to another and plugged it in and it's not turning on. The light is on but motor isn't starting. Any Ideas?
ck power at new house ( the plug ) do the lights come on in frig ? if so look for wires under frig that may have been puled off during move .. this should not be a tuff one . / the frig should not been damaged by beeing off . did you lay it down dueing the move ( it chould have been kept upright .. as laying down causes the oil to ru up in the cold coil .) hope this hepls mm
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Need to know how to change break light bulb
Open the truck & remove philips head screw that is located to the left of the tail light housing in the trunk lid weatherstripping housing area. Next unscrew the trunk lining screw to fold back the trunk lining to get at the two plastic wing nuts that hold the light housing.
Unscrew these two wing nuts and slide the housing out, then remove the bulbs and replace. Bulbs come out similarly to how you'd replace the front headlight bulbs (unplug, twist counter-clockwise to unlock and remove old bulb, replace with new bulb and turn clockwise to lock, plug back in).
Oct 16, 2010 | 2006 Chevrolet Malibu
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
I have two older craftsman openers. We had a storm come thru that effected other things at house. Garage doors both went up but will not go back down. No reset on opener. Unplugged and plugged back in, no...
How about some info to work with? Do they have electric eyes? Are they lit? What model Did you put in a Home-owners claim on your damaged household "other things"?
Oct 14, 2009 | liftmaster Chamberlain Garage Door Opener...
I move from my house and after my pc not working... why?
whats probelm is create in your pc in your home please difine than i solved your problem
May 28, 2009 | Intel D915GAV Motherboard
Fridge not cooling
Make sure coils underneath or backside are clean of dirt. Make sure compressor is humming when running. You can tell by moving fridge out and it will be at the back side of the opening on the bottom side of fridge. It will be about the size of a soccer ball. If it has a little of vibration and might be alittle warm to touch. Also open door and make light comes on inside. In newer homes these days they are using ground fault interceptors. Even tho this one is not plugged into one that has the resetable breaker check other walls for one that does have the little red and black push buttons. They sometimes wire some into one ground fault, when that pops, it shuts power to the others. Our house is that way, I have to go to our bathroom and reset it to make the ones in the kitchen work.
Nov 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
105 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
