Question about Sherwood SR1 Regulator
Old style sherwood blizzard regulator problem
Regulator free flows - have not used it for many years - appears I need to get in behind the diaphram to adjust - don't want to ruin
  • 3 Answers
The front of the regulator should twist off with a little effort then exposing the purge diaphram, check your dry cracking and deteireation, you shoud be able to dismantle the reg and assmeble easily, and when you do get it open lube the piston and diaphram with silicone grease, but not the side you breath from just the mechnical side.
Posted on Feb 06, 2009
Not staying lit.
Hi Matt
Check your regulator to make sure it is getting the gas needed, sometime a sharp rap or two on the regulator will free up the needle and diaphram or your regulator may be adjustable.
If that does not work check your flow from the burners it'self...could be plugged up gas holes.
Please rate me
Bud
Apr 13, 2013 | Weber Summit S-470 Propane Grill
Gas is barely flowing-used to hear hiss before I lit. Tried replacing pressure valve and got a new tank of gas. Also disassembled manifold and cleaned out all burners.
I had the same problem years ago with an old charbroil and ended up fixing by replacing the threaded female gas connector on the regulator with one of the old style male inside threaded type. This is the connector that connects the hose/regulator to the propane tank.
Aug 20, 2010 | Weber Genesis Silver C Grill
The regulator is free flowing the opupus is also free flowing . They are Magnum blizzard by sherwood
Your regulator requires servicing as this problem could be caused by either excessive pressure in the LP line to your Reg or the valve in the reg has become defective.
Jul 23, 2010 | Sherwood SR1 Regulator
My reg simply free flows when connected to the tank. Its the first time it has ever done this. Is this an easy fix, or should I start to worry? the thing is this reg is at least 10 years old so I don't...
Turn the regulator mouthpiece down
Blow air back into regulator
Make sure the sensitivity slide is toward the edge of the regulator
Turn the gas on quickly when the rig is mounted. Turning on slowly results in free flow
Jul 12, 2010 | Poseidon Odin/Jetstream Regulator
Low flame
Next time you use the grill turn the gas on slowly. For some unknown reason when turned on quickly the regulator reduces the gas flow.
Another problem with some gas fittings is an auto shutoff if detects the slightest leak. Sometimes the shutoff is not 100% and allows a small amount of gas causing the weak flame.
Apr 27, 2010 | Weber Genesis Silver B Grill
I need to know how to install a fuel pressure regulator on a 98 GMC K3500 4x4
The fuel pressure regulator is located under the upper intake manifold or plenum. This large aluminum casting must be removed for access.I assume this is a 454 c.i.d.old body style pick up. 2000 was a split year for GM. Both old and new body styles.
Feb 24, 2010 | 2000 GMC Sierra C/K3500
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
I have an old Briggs and Stratton engine 16hpv. I
I am trying to find you a spring..i have a bunch of old stuff out back. give me a couple days. It holds the diaphram steady to prevent chattering of the rubber while fuel is flowing...:)also what year is your briggs and model?
Sep 07, 2009 | Garden
Sherwood SR1 Regulator Logo
997 people viewed this question
Top Sherwood Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Sherwood Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
