Question about Foxconn 848P7MB-S Motherboard
Can not get motherboard to boot up
No pwer to keyboard,pci slots, mouse and front usb light does not come on. I am getting power to cpu fan, cd rom and hard drive
  • mmachajewski Jan 31, 2009
    fresh placed mother board
  • Misterixas May 11, 2010
    How does this happen? Is it your fresh-placed motherboard or you have changed any hardware?
    Sniper:
  • 96 Answers
Check if the 20 (24) pin connector is properly inserted in to motherboard.
This also may happen if your CPU is not supported by motherboard's manufacturer. Check the motherboard's manual or manufacturer's web-site to ensure the compatibility and if so, check the correct jumper settings (usualy to set the correct voltage for CPU)
Posted on Feb 02, 2009
    Scholar:
  • 50 Answers
The things youre describing that are not controlled by the same power connectors. the 1st set that works are powered i think by the main large rectangular power connector. the stuff that's not working require more power connections. the cpu fan has a small wire that connects to a small connector on the motherboard right near the cpu. the optical drive connects to one of the the 4 pin power connectors coming from the power supply, same with the hard drive- same power connector. the front usb light is going to connect to a specific tiny 2 pin connector on the mobo, it will be labeled with tiny white letters-- try to find or download the manual. godo luck!
Posted on Jan 31, 2009
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
Motherboard DP35DP Installation Problem
You should try a regular ps/2 mouse and keyboard.  You probably don't have the USB drivers installed for the new board.  After you get booted into windows you'll be able to install those.
Oct 12, 2007 | Intel Motherboard
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
Why wont the mouse,keyboard and monitor not work after cpu,pwer supply install...
If the motherboard used to work with the old cpu and power supply, but does not with the new cpu and power supply, then probably the cpu or power supply is bad.
Why did you change the cpu and power supply?
If the power supply went bad, it could have overloaded the mother board as well as the old cpu.
If you think the old cpu went bad, how do you know it was not actually the motherboard that went bad?
All I can suggest is that you double check all the connections.
If you have USB mouse and keyboard, try a DIN connected pair.
If you are using the onboard graphics, try a PCI express card instead.
Tell us if there is any front light activity from the power switch, drive, etc.?
Dec 21, 2010 | Biostar P4M900-M4 Motherboard
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
PROCESSOR, MOTHERBOARD AND POWER
This is a printout of the specification for the Gigabyte motherboard GA-MA785GT-UD3H
products_spec.aspx&websource=www.google.com.au%2fsearch%3fhl%3den%26q%3dgygabyte%2bga-ma785gt-ud3h%2bspecs%26btng%3dgoogle%2bsearch%26meta%3d%26aq%3df%26oq%3d&sourceweb=
arrow_down_deepgray_7x7.gif Specifications CPU
  1. Support for AM3 processors: AMD Phenom™ II processor/ AMD Athlon™ II processor
Hyper Transport Bus
  1. 5200 MT/s
Chipset
  1. North Bridge: AMD 785G
  2. South Bridge: AMD SB710
Memory
  1. 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory (Note 1)
  2. Dual channel memory architecture
  3. Support for DDR3 1800(O.C.) /1666/ 1333/1066 MHz memory modules
Onboard Graphics Integrated in the North Bridge:
  1. 1 x D-Sub port
  2. 1 x DVI-D port (Note 2)(Note 3)
  3. 1 x HDMI port (Note 3)
Audio
  1. Realtek ALC889A codec
  2. High Definition Audio
  3. 2/4/5.1/7.1-channel
  4. Support for Dolby Home Theater
  5. Support for S/PDIF In/Out
  6. Support for CD In
LAN
  1. Realtek 8111C chip (10/100/1000 Mbit)
Expansion Slots
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16_1) (Note 4)
  2. 1 x PCI Express x16 slot, running at x4 (PCIEX4_1) (Note 5)
    (The PCIEX16_1 and PCIEX4_1 slots support ATI Hybrid CrossFireX technology and conform to PCI Express 2.0 standard.)
  3. 3 x PCI Express x1 slots (The PCIEX1_2 and PCIEX1_3 slots share the same PCIe bus with the PCIEX4_1 slot.) (Note 5)
  4. 2 x PCI slots
Storage Interface South Bridge:
  1. 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
  2. 6 x SATA 3Gb/s connectors supporting up to 6 SATA 3Gb/s devices
  3. Support for SATA RAID 0, RAID 1, RAID 10 and JBOD
iTE IT8718 chip:
  1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394 T.I. TSB43AB23 chip
  1. Up to 3 IEEE 1394a ports (1 on the back panel, 2 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
USB Integrated in the South Bridge
  1. Up to 12 USB 2.0/1.1 ports (6 on the back panel, 6 via the USB brackets connected to the internal USB headers)
  1. 1 x 24-pin ATX main power connector
  2. 1 x 8-pin ATX 12V power connector
  3. 1 x floppy disk drive connector
  4. 1 x IDE connector
  5. 6 x SATA 3Gb/s connectors
  6. 1 x CPU fan header
  7. 2 x system fan header
  8. 1 x power fan header
  9. 1 x front panel header
  10. 1 x front panel audio header
  11. 1 x CD In connector
  12. 1 x S/PDIF In/Out header
  13. 2 x IEEE 1394a header
  14. 3 x USB 2.0/1.1 headers
  15. 1 x parallel port header
  16. 1 x serial port header
  17. 1 x chassis intrusion header
  18. 1 x power LED header
  19. 1 x clearing CMOS jumper
  1. 1 x PS/2 keyboard or PS/2 mouse port
  2. 1 x D-Sub port
  3. 1 x DVI-D port (Note 4) (Note 5)
  4. 1 x HDMI port (Note 5)
  5. 1 x optical S/PDIF Out connector
  6. 1 x IEEE 1394a port
  7. 6 x USB 2.0/1.1 ports
  8. 1 x RJ-45 port
  9. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
  1. ITE IT8718 chip
H/W Monitoring System voltage detection
  1. CPU/System temperature detection
  2. CPU/System fan speed detection
  3. CPU overheating warning
  4. CPU/System fan fail warning
  5. CPU/System fan speed control (Note 6)
BIOS
  1. 2 x 8 Mbit flash
  2. Use of licensed AWARD BIOS
  3. Support for DualBIOS™
  4. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
  1. Support for @BIOS
  2. Support for Q-Flash
  3. Support for Xpress BIOS Rescue
  4. Support for Download Center
  5. Support for Xpress Install
  6. Support for Xpress Recovery2
  7. Support for EasyTune (Note 7)
  8. Support for Easy Energy Saver
  9. Support for Time Repair
  10. Support for Q-Share
Bundle Software
  1. Norton Internet Security (OEM version)
Operating System
  1. Support for Microsoft® Windows Vista/ XP
Form Factor
  1. ATX Form Factor; 30.5cm x 22.9 cm
Note (Note 1) Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connection by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) If you are installing a PCI Express graphics card, be sure to install it in the PCIEX16_1 slot.
(Note 5) The PCIEX1_2 and PCIEX1_3 slots share bandwidth with the PCIEX4_1 slot. When the PCIEX4_1 slot is populated with a x4 card, the PCIEX1_2 and PCIEX1_3 slots become unavailable.
(Note 6) Whether the CPU/system fan speed control function is supported will depend on the CPU/ system cooler you install.
(Note 7) Available functions in EasyTune may differ by motherboard model.
Aug 07, 2009 | Gigabyte Computers & Internet
PRINCECHARMING2010@YAHOO.COM
CPU
  1. LGA 775 for Intel® Pentium® D / Pentium® 4 processor
Chipset
  1. North Bridge : Intel® 865G GMCH
  2. South Bridge : Intel® ICH5
  3. Realtek ALC653 Codec
  4. EP82562G chip (10/100Mbit)
Front Side Bus
  1. 800 / 533 MHz FSB
Memory
  1. Type: Dual Channel DDR 400 / 333 / 266 support
  2. Max capacity: 2 GB
  3. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. Internal I/O Connectors
  1. 1 20-pin ATX power connector
  2. 1 4-pin ATX 12V power connector
  3. 1 floppy connector
  4. 2 IDE connectors
  5. 2 SATA connectors
  6. 1 CPU fan connector
  7. 1 system fan connector
  8. 1 front panel connector
  9. 1 front audio connector
  10. 1 CD In connector
  11. 1 power LED connector
  12. 1 USB 2.0/1.1 connectors for additional 2 ports by cables
Expansion Slots
  1. 1 x AGP 8x slot
  2. 3 x PCI slots
  1. 1 PS/2 keyboard port
  2. 1 PS/2 mouse port
  3. 1 parallel port
  4. 1 serial port (COMA)
  5. 1 VGA port
  6. 4 USB 2.0/1.1 ports
  7. 1 RJ-45 port
  8. 3 audio jacks (Line In / Line Out / MIC In)
Form Factor
  1. Micro ATX
  2. 24.4cm x 21.2cm
H/W Monitoring
  1. System voltage detection
  2. CPU temperature detection
  3. CPU / System fan speed detection
  4. CPU warning temperature
  5. CPU / System fan failure warning
  6. CPU smart fan control
BIOS
  1. 3Mbit flash ROM
Other Features
  1. Supports @BIOS
  2. Supports Download Center
  3. Supports Q-Flash
  4. Supports EasyTune 5 (only supports Hardware Monitor function)
  5. Supports Xpress Install
  6. Supports Xpress Recovery2
  7. Supports Xpress BIOS rescue
Remark
  1. Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
  2. Due to most hardware/software vendors no longer offer support for Win9X/ME. If some vendors still has Win9X/ME drivers available, we will publish on website
Jan 16, 2009 | Computers & Internet
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
I don't know the parts of the motherboard.
What motherboard would you like to know the layout of? Although, many motherboards are different, most of them have the same basic parts. From back to front, you have the communication ports; (usually from top to bottom, varies by manufacturer)mouse/keyboard, usb 1.0/1.1/2.0(make and model dependant) serial, paralell, vga/monitor, then sound: midi, headphone/speaker out, line out, microphone in.
then on the board, processor, somewhere near it, cache, i/o chip, north bride chip, wich is responsable for memory(ram) access, ide(cd rom/ hard drive access) ports and power connector/s,
memory slots
then the south bridge chip witch controls isa port(old), pci slot, agp/pci-e slot (video card) along with the cmos battery, bios, and various other slots/connectors (such as fan, power button and so on) and chips, wich vary by manufacturer and model.
Dec 27, 2007 | Computers & Internet
Foxconn 848P7MB-S Motherboard Logo
246 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
