Question about Yamaha RX-V463 Receiver
Zune and yamaha RX-V663 Receiver
How to i hook up my zune to my yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Posted on Feb 28, 2009
Yamaha rx-v663 how to set and lock sound program
once you set the audio program for an input, it should stay set even if you power the unit down. As far as locking that program so that it cannot be changed - no there isn't a way to do that.
May 07, 2015 | Yamaha RX-V663 Receiver
How do you hook up a speaker selector to a rx-v663?
By following its specific instructions. Tell us about it.
Mar 06, 2011 | Yamaha RX-V663 Receiver
Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
May 16, 2010 | Yamaha RX-V663 Receiver
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Dec 29, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V663 display is not working
If you have your receiver hooked up to a TV or Monitor, press "Menu" then toggle to section "5" "option menu" and check your "Dimmer" setting "0" is highest. Then check "FL Scroll" and the choice is "Cont". This info is on page 96 in your manual, if you don't still have a copy, here's the link
Hope this helps. If you still have a problem, post a comment and I will help you further.
Dec 26, 2009 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Feb 10, 2009 | Yamaha RX-V463 Receiver
Tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Jan 19, 2009 | Yamaha RX-V663 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V463 Receiver Logo
641 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
