Coaxial cable works but not RCA
I intended to connect my TV via the RCA cables supplied with the NS-DXA1-APT. I first set it up using the coaxial cable as a quick check to see if my antenna reception was adequate.
The signal to the TV via the coaxial cable was fine. now I wanted to switch over to the RCA cables and they don't work at all. Is there a one shot limit to connect which locks the other option out? Seems weird, but I've tried several different cable sets and two different TVS and only the coax works. any ideas?
    Problem Solver:
  • 5 Answers
You have a DEFECTIVE box. There is no 'lock out feature on the Insignia. If your cables are ok, and you've tried it on another TV, then its the box.
Posted on Jul 29, 2009
Do you have to have an optical cord from receiver to tv..koss model ks3102..if not i have rca cords were do cords go.
HD broadcasts by TV stations are often broadcast in Dolby Digital. If your TV can output Dolby Digital or HD then you will need to have the TV connected to the receiver via either the optical in, or the coaxial in. If the receiver can get the Dolby signals via the Coaxial and the TV can send them via a Coaxial socket it should work. Don't forget to set your HD set to output Dolby signals. If the TV or Receiver can only send Dolby via the optical you will have to use that. Optical cables can be picked up cheap these days. I have seen them in pound shops!
Sep 09, 2015 | Audio Players & Recorders
Insignia ns-dxa1-apt receiver is not picking up signal and all cables are connected correctly, we have suddenlink cable. Does this receiver not work with them?
Hi- My name is Shannon and I am with Suddenlink. If you are still experiencing trouble, I would be happy to assist you. Please email me directly at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 04, 2012 | Insignia NS-DXA1-APT
I am having trouble connecting dvr to dvdvcr to older tv
This can get tricky sometimes. It depends if you're connected the DVR to the tv via RCA cables or coaxial cables. For coaxial, connect from the TV's in to the DVD/VCR combo out. Coaxial from your DVD/VCR in to your DVR out. set your VCR/DVD to channel 3/4 depending on your manufacture as well as your tv. If this doesn't work, usually your tv provider may be able to help you out.
Mar 01, 2011 | Televison & Video
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Have an Insignia (NS-DXA1-APT). Have tried 3
connect up another tv and see if it is the tv or where you live.if the tv is the culprit then you have a defective tuner in the tv and is probably is not available.
Jul 18, 2009 | Televison & Video
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
No display
Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
Sep 02, 2007 | Philips DVDR3455H/37B
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
