Question about Sony PlayStation Portable (PSP) Console
My PSP's power light in the lower right corner won't turn on.
What am I to do?
  • Anonymous Feb 02, 2009
    I might have the same problem
Red power light blinks
Posted on Feb 01, 2009
3 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: PSP GAME
My guess is you used a regular Q-tip to clean the laser lens and it left cotton hairs on the lens. I like to use the foam swabs. You can press the little swtich sticking up inside the UMD compartment. It is on the left and back about 1 inch. When you press it you should see your Laser light up and the spindle spin. This will tell you if the laser and spindlge work. You can physically move to Laser over to the right a few clicks and put the UMD back in it and look to see if the laser moves left and right. if it still does light up, spin the spindle and move left and right, then it probably will need its lens cleaned.
Posted on Jan 23, 2008
SOURCE: one red light on lower right hand corner, e74 message on screen
you should just basically call the microsoft company that would help a whole lot, and maybe it could be a ring of death but yeah just call them up.
Posted on Jul 15, 2009
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
I have a psp1000 it was fine until is started powering down all by itself. i put a brand new battery in it and shortly after it powers up, it powers down. What do i do now, and would it be very expensive...
Here are some instructions to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 05, 2011 | Sony PlayStation Portable (PSP) Console
    Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
    Here are some instruction to help fix your problem.
  • May 04, 2011 | Video Game Consoles & Games
    I have a psp and i dont know if the psp is broken or is it my charger or battery please help sony model psp-110 battery pack 3.6
    Hello there,
    When you charge the PSP, does the charging light indicator at he lower right corner lights up as red? If not, then the battery is not being charged at all. But if it does lights up but does not power up the PSP, then the first this to troubleshoot this problem is put in another battery pack. If it powers up, then your battery needs to be changed.
    Please let me know how this goes. Thank you for using FixYa.
    Dec 19, 2010 | Sony PlayStation Portable (PSP) Console
    Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
    Hello there
    You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
    Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
    Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
    Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
    Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
    Oct 10, 2010 | Sony PSP (Piano Black)
    Nothing comes up on screen even after switching it on
    you may have the power-save option on in the psp settings which automatically turns off the light after a certain aount of time to save battery life. just go to settings and find that setting and turn it off if you want that light o stay on
    Jun 22, 2010 | Sony Buzz! Master Quiz for PSP
    Psp hanging
    The circle in the lower right hand corner of the PSP screen is showing that a disc is being read. I would say take out any discs you're using and try to run things directly off of the memory card. I'm not going to dive into anything else, because Custom Firmware on the PSP is a tricky situation that you really shouldn't be asking about on FixYa.com.
    Oct 06, 2008 | Sony PlayStation Portable (PSP) Console
    My psp wont charg
    If it won't charge and wont power up then same thing happened to me. If you are willing to open up your psp there is a video on youtube that can show you whats wrong. The cable that connects the buttons on the right side most likely disconnected from the main board and the right side of the psp including the buttons, the power switch and the top right trigger won't respond. When you try to turn on the psp and when its charging if the light won't come on then you might have this problem.
    May 10, 2008 | Sony PlayStation Portable (PSP) Console
    Power problems
    Hi Gohan102,
    Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
    Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
