Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
TV was working perfectly; and now i dont get cable or regular....
My new HDTV was working perfectly; and now i dont get cable or regular analog. The analag pictures are so snowy its not even funny. What should I do.
First it was perfect, then it went and came back, it did that twice through the day, but the second time it went it did not come back.
Superbowl Sunday is tommorow and I NEED this fixed.
Can anyone help?
    Problem Solver:
  • 5 Answers
Most tvs that are digital have already switched over and thats problably what your tv did and i don't know how to change or fix that problem
Posted on Jan 31, 2009
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ...
www.tomsguide.com/forum/53920-4-basic-channels-hdtv-cable What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
Is Orion TV model 1929 ready for Feburary 17, 2009 Digtal conversion without the converter box ?
is the model number correct? Can't find the details of your television.
Does your tv use digital input? or analog if its analog then you need the box.
May 04, 2008 | Televison & Video
Sound no picture
I think you hit the wrong button before....
To restore the settings please try to restore factory setting and see what happen..
Nov 22, 2011 | Samsung LN22A450 22 in. LCD HDTV
Tryin to play my ps3 through hdmi, but all im getting is a blue screen. but i tried it befor and it worked now it dont any suggestions on why?
Did you move your PS3 back to a regular tv set? If this is the case then you have to 'reset' your PS3 to play through the analog hook-ups.
This is easily redone by doing this
1, With the PS3 "OFF", Press and hold the power button, keep holding the button down till you hear 2 rapid beeps. IMMEDIATELY remove your finger from the power button (on the new slims continue to hold the button until the unit powers itself off).
2. Press the power button a second time and let the unit power down.
3. Power the PS3 back up, you should have playback through your analog hook-ups.
This little fandango will have to be repeated every time you relocate your game center on an HDTV and then back to a regular tv.
If this isn't the case, the first thing I would check is that your HDMI cable hadn't gone bad. Simply change that cable out with another and annotate the results. Then test the HDMI port with another playback device (blu-ray or up scaling dvd player) and see that the port isn't bad.
Other than these test hints, there may be little else to troubleshoot.
Hope one of these helped...
Oct 25, 2010 | Televison & Video
I just bought the sc-pt660.Is there any way for me to hook my regular tv(not a flat screen or hdtv)or my time warner cable box to this to get sound from movies on tv.I dont see any audio in ports.thanks
You can use the PANASONIC AUX IN ports for your TV or CABLE BOX audio, unless you run the DIGITAL CABLE into the PANASONIC, this may be available on the CABLE BOX or your TV, my suggestion is if you use the Cable box to view TV then use the CABLE BOX AUDIO OUTPUTS, you would be better with the CABLE BOX digital output INTO YOUR panasonic, but if it is already being used take the AUDIO out analog connection from your cable box into your Panasonic AUX INPUTS, then set the Panasonic to AUX IN mode.
Feb 28, 2009 | Panasonic SC-PT660 Theater System
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
No analog stations on my hdtv 37 inch, have no digal box just regular cable, regular cable works on normal tv
Try an antenna if you want to get analog over the air. I have a feeling that with the way the standards are changing, you will only be able to get digital channels. After February, the analog channels won't be around.
If you are using cable tv you need an HDTV box to get high def.
Jun 13, 2008 | RCA HD52W59 HDTV Projection Television
Apex tv 2024
As long as the New Cable boxes have an analog output they will work fine.
Dec 27, 2007 | Apex Digital AT2002S 20" TV
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Computer Repairing
Computer Repairing
