Question about Kenwood KDC-1022 CD Player
Can I plug an mp3 player into the unit ???
I believe the unit has your standard 2 X RCA sockets in the rear of the unit (not sure only felt them there)?? but I cannot find the a AUX button?? cheers !
    Brigadier General:
  • 6,966 Answers
Hi, A wild guess, the 2 X RCA are lineout intended for external amplifier hence no AUX selection in your front panel buttons, but of course I might be off. I have similar problem with a Pioneer model and an MSI MP3 player. My solution was to install a stereo FM RF Modulator similar to Delphi SA10003 or an AudioVox Rf Modulator FMM100a. The MP3's output was fed to the modulator which turns it into an FM broadcast. The car stereo picks it up as an FM signal. Hope this gives you some idea. Good luck and kind regards.
Posted on Jul 31, 2007
How do i reset my rca mp3 player
Disconnect the power while unit is turned on. Then hold the power button for about half minute. Then plug back in and turn on.
Aug 30, 2015 | RCA Th1611-A Personal Mp3 Players
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
I need directions to connect my mp3 player to my pioneer deh 3700mp car stereo
Assuming that you're not trying to connect an iPod or iPhone, you will need an additional adapter. For your particular unit, that will be a Pioneer CDRB10 Auxiliary input adapter for P-Bus receivers (approximately $40). You'll also need a stereo mini plug to RCA adapter (about $15 for a good one of around 6 ft). You'll plug this adapter into the headphone jack of your MP3 player and the RCA ends of the adapter into the RCA ends of the Pioneer CDRB10. Then for the hard part, you'll need to plug the other end of the Pioneer CDRB10 to the rear of your stereo head unit. That will mean pulling the unit out and doing some fishing so that the wires are hidden and leading to a location where you can functionally attach and detach your MP3 player.
Oct 20, 2013 | Pioneer Audio Players & Recorders
I have a Kenwood KR-V6080 amp and I have tried playing a Sony MP3 player through the phono and cd sockets on the amp but the sound is not good. I have also tried to change the settings on the MP3 player...
"Not good". What does that mean?
It SHOULD work. Look at the MP3 player's volume controls.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
Jul 01, 2011 | Audio Players & Recorders
What is the largest sd card it would read. I bought a 4gb and it won't read it it also makes the unit freeze but when i take it out it works fine
System Name RCA RCA M2000 System Type   Standard Memory 0MB (Non-removable) Maximum Memory 2GB SecureDigital Expansion 1 Slot for SecureDigital System Name RCA RCA M2000 System Type   Standard Memory 0MB (Non-removable) Maximum Memory 2GB SecureDigital Expansion 1 Slot for SecureDigital According to the research I did...it looks like the largest card you can use in the RCA M2000 MP3 player you have is 2 GB...
Good Luck,
I hope this helps,
Please rate me
Dec 01, 2009 | RCA M2000 MP3 Player
I don't know how to charge it. It doesn't have a
Hi
This unit charges via the USB cord when it is directly connected to your computer or other device with a USB port. You can also purchase a home AC adaptor but as far as I am aware this does not come as standard with the unit itself.
Hope this helps. Thanks for using FixYA.
Nov 04, 2009 | RCA OPAL M4001 MP3 Player
Mp3 player
you'll need the reqired plug for this.like earphone plug or rca plug.depends on the socket.mp3's usually use the earphone plugs because it's small.after having all the necessary plugs, plug it where it says audio input or input or aux(auxilliary)
May 13, 2009 | RCA RS2047 Shelf System
Mp3 hook up
Use the mp3 ( line out, audio out), probably a mini plug 1/8th" and get a plug adapter to the standard RCA audio jacks, this is a splitter ( ie. 1 in 2 out ) and go into one of the denon audio in, there are 7 , this is unless you have a digital out on your mp3 player, then use this connection into the denon, 2 optical, and one coaxial which is not common on mp3 players, my bet it to use the digital optical for best quality, but this is possible only if your mp3 unit has that option.
Feb 05, 2009 | Denon AVR-1905 Receiver
Rear speakers dont play with connection box
I believe this is a wiring incompatibility problem. The reason I say this is because when the mp3 player is out the jack which contains switches engages the front L&R and the Rear L&R, when the plug is inserted into the jack the jack switches should remove the audio input to the amplifier and replace it with the audio from the mp3 player. The switches should then send sound to the front L&R and the Rear L&R but the only change should be that the mp3 player is switched in instead of the audio from the raido unit. what is happening is that the jack switches are only switching in the front L&R speakers. This just might be a function of the unit. check the owners manual. here is a site that has the manual: http://www.docs.sony.com/release/XAV7W.PDF
Sep 21, 2006 | Sony XAV-7W 7 in. Car Monitor
Kenwood KDC-1022 CD Player Logo
191 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
