Question about Symbol PDT 3100
Troubleshooting screen my screen says command or filename not recoginzed D:/> and i cant get back on the main menu
  • 97 Answers
You will need to reload the drivers and application. if the problem persists, there is a hardware fault.
Posted on Mar 26, 2009
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
How do I set time on a 4Gb Sansa Fuze?
Press the MENU button to bring up the main menu. "Turn" the command wheel to select "Settings" and press the central button. "Turn" the command wheel to select "System Settings" and press the central button. "Turn" the command wheel to select "Date & Time" (it's not initially on the screen, the screen will scroll when you hit the bottom) and press the central button.
Select the desired field by "turning" the command wheel and either press the central button or click the right side of the command wheel. Change the field by "turning" the command wheel. When you have the field set properly, click the left side of the command wheel and you can then select another field.
When done, repeatedly click the left side of the command wheel to back out of the menu system.
Apr 26, 2011 | Audio Players & Recorders
Problem after loading LWP.hex and UPD802.hex
You might be loading inccorect LWP or there is a hardware problem, in any case we can help. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Sep 02, 2009 | Symbol PDT 6846 Portable Terminal
Its not letting me get out of DOS
CTRL + C will halt the process.
Feb 01, 2009 | Symbol PDT 3100
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
Need help installing the firmware for an HP LJ p3005n. I have the download, and the printer is locally connected *USB*
David,
As per the instructions from HP for windows systems:
If the device is shared on the network, then the following command can be issued from a command prompt: copy /b FILENAME \\SHARENAME\PRINTERNAME
where FILENAME is the name of the .RFU file,SHARENAME is the name of the machine, from which the printer is being shared, and PRINTERNAME is the printer's share name.
If the device is attached locally, then the .RFU file can be sent directly to the printer with a COPY command from a command prompt or DOS window:
copy /b FILENAME PORTNAME
where FILENAME is the name of the .RFU file and PORTNAME is the name of the appropriate device port (such as LPT1).
The following can be set on the computer to help address a timeout message that may occur during an update:
From a command prompt or DOS window type the following command and press the enter key:
Mode lpt1:,,p
If the device is attached to a parallel port other than LPT1, then substitute the proper LPT port number in the MODE command. Once this command has been set the file can then be copied to the printer with the above mentioned COPY command.
NOTE: When the upgrade process has completed the LaserJet will reboot. Once the printer is back online, print a Configuration Page and verify that the new firmware has been installed.
Chris
Alkaline Water
Dec 05, 2008 | HP LaserJet P3005n Printer
Cant see ps3 main menu
when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
System not booting
take windows xp cd and repair from the cd
Sep 01, 2007 | Microsoft Windows XP Professional With...
Symbol PDT 3100 Logo
114 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
